Buffer for Pass' LXmini OX/EQ
Old 12th June 2018, 11:53 PM   #31
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
That would be up to DIYaudio management.
I don't see a shortage though. Initial offering is qty 100 pcb+fet kits and
100 pcb+fet+resistors+caps. I don't know the specific timeline for the
Galaxy 2u 230x230 chassis with the rear panel holes, but it should be
pretty quick.
I'm sending those first 200 pcb+ kits out in a week or so.
After that, I have 150,000 Jfets and a big pcb manufacturer standing by...
Old 13th June 2018, 01:02 AM   #32
drpro is offline drpro  United States
Hmm, methinks we might run out in a month or two
Old 13th June 2018, 03:25 AM   #33
dtaylo3 is offline dtaylo3  United States
Only 150,000? It may be some time before we reach a supply problem or "im-Pass" given that number.
Old 13th June 2018, 12:52 PM   #34
JOHNNYCR100 is offline JOHNNYCR100  Abu Dhabi
Default no problem with supply
I think thats just the stash under Nelsons bed, he is just cleaning house!
Johnny
Old 13th June 2018, 02:21 PM   #35
Davey is offline Davey  United States
Originally Posted by techwazz View Post
I have bought the plans from Mr SL since 2 years ago but have been holding back on building them because of the previous non availability of an analog DSP option.
Two years you've been missing out on enjoying the LXmini system for lack of a non-DSP option?
Dave.
Old 15th June 2018, 04:36 PM   #36
mjwolf is offline mjwolf  United States
Dave.
I have been waiting about three and half years for a analog option. I do not like any of the DSP options that use mini-dsp products.
I prefer the Par-Metal enclosures over the HiFi2000 enclosures. I have not been able to get a black anodize enclosure from Par-Metal since they had a fire.
Old 15th June 2018, 05:22 PM   #37
There are numerous LXmini users who utilize non-miniDSP DSP products. It's a bit cumbersome to transfer the settings in some cases, but it's certainly doable.
However, I gather your issue is with ANY DSP products in this application. It's a fair point.
As a strictly analog solution, the Pass version probably represents the top of the heap, since op-amp versions might not be acceptable to some as well.
Although not official, I'm aware of about a half-dozen users who have implemented the crossover/EQ (a simplified version) at speaker level. (Myself included.)
Regardless, as I've mentioned on the OPLUG forum a few times. The ASP/DSP/whatever line-level implementation is a smallish percentage of the conceptual/engineering scheme that went into the LXmini design. The idiom....to (not) see the forest for the trees....is applicable here.
Dave.
Old 17th June 2018, 08:32 PM   #38
Vortex is offline Vortex  Hungary
Vortex's Avatar
Send a message via ICQ to Vortex Buffer for Pass' LXmini OX/EQ
Is miniDSP soooo bad, gentlemen ? I'm just considering it for everything (room, EQ, crossover, DAC) for my big active 3-way but I recently ran into posts where some people really dislike it - just want to know, why and if there're better recommended versions, what would be those ?
Other question is the alternatives. Room HAS to be corrected somehow. Shall we play around with extensive room modding, or chop the woofer's baffles due to complete redesign, etc.. ? SOME kind of DSP is needed I think, our ears is still mostly sensitive to amplitude. I thought I'll be just fine with a 24/96 capable miniDSP miniSHARC (i2S in-out) with a 8-channel 24/96 DAC. At least for the very beginning. Now I reconsider again based on what I read here and elsewhere.. Any advice.. ?
IT guy with a broad taste of music: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16
Old 17th June 2018, 09:33 PM   #39
wcwc is online now wcwc  United States
There are quite a few offerings that minidsp has. Much of the audio quality seems to come from people who bought the original 2x4 miniDSP. It worked, but many didn’t think the sound quality was audiophile grade. They have come out with a multitude of different models since then. All improved on the original model. They are trying to make affordable units that people are willing to buy, so they are designing to a certain price point. Like always there are compromises.
Old 18th June 2018, 03:48 AM   #40
Vortex's Avatar
Understand. Sounds legit. Could you recommend me a more high-end DSP brand with at least the same functionality.. ? Money is certainly not unlimited for me either but I'm willing to check more expensive alternatives in favor of sound quality. (I know it's a bit off here but I really just need some recommendations from the other end of the ruler and then I can study them too). Thanks.
Buffer for Pass' LXmini OX/EQHide this!Advertise here!
WTB Pass B1 Buffer dublin78 Swap Meet 3 22nd June 2016 01:55 PM
Pass B1 Buffer Preamp help orij Pass Labs 8 18th May 2013 09:15 PM
Nelson Pass B1 Buffer zcables Swap Meet 3 14th May 2013 10:08 PM
Pass B1 Buffer mantha3 Pass Labs 2 26th January 2012 11:35 PM
Need help with Pass B1 Buffer benproiii Analog Line Level 0 30th August 2011 04:18 PM
