Passive/active preamp (transformers, resitors)
Old 16th March 2017, 07:02 AM   #1
bbest is offline bbest
Cool Passive/active preamp (transformers, resitors)
Hello!
I have balanced source on ES9018 and balanced beta22. Besides this intend to assemble stax balanced amplifier. Wanted to use some high quality volume control for all amplifiers.
It is dilemma what is best choice: TVC transformers or resistive preamp. Transformers could be choosen between Sowter 9335, S&B, Silk STA-522A and others.
For resistive preamp must be use buffer. I choose amb alpha24 with opams OPA1612, OPA1632, fully-differential outputs. Also good choice is Khozmo preamps with z-foil resistor. The best performance gives ladder or buffer stepped attenuators. Quality of resistors does matter. Best choice is z-foil.
The main question: what is bestes - transformers or resistive preamp? Needed ultimate sound quality after simple volume control.
What your opinion?
Old 16th March 2017, 07:06 AM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Transformers, in my experience, make the best volume controls. If you wish to use a buffer, don't make it an opamp, go for something classA (which normally means discretes).
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 16th March 2017, 07:29 AM   #3
abraxalito, thanks for opinion. How you think, what transformers are best (cost not more than 1000$ for pair)?
Opamps are really not good choice. The same question, what better to choose for classA(discretes), may be something on ebay?
Old 16th March 2017, 11:46 AM   #4
abraxalito's Avatar
For TVC you could wind one yourself on a ferrite core. I bought myself some suitable cores a while back - the bobbins had dozens of pins to bring out lots of tap points from the windings. Since acquiring them though I've been too lazy to get on and build them into TVCs.
I don't have any experience of buying audio kit on eBay so I'll pass on your second question.
Old 17th March 2017, 09:15 AM   #5
As for transformers vs resistors: transformers best on low level attenuation. But on high level, near proportion 1:1, resitors could make competition with transfomers.
Old 23rd March 2017, 04:04 PM   #6
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Here's a well regarded TVC available for as low as $200 for a stereo pair - see them near the bottom of the linked page. That said, I have no personal experience with them.
intact audio
Passive/active preamp (transformers, resitors)Hide this!Advertise here!
(Gainclone Preamp) ACTIVE or PASSIVE ? nickthevoice Chip Amps 27 26th July 2011 10:28 AM
Touch-sense/remote active/passive preamp wakibaki Analog Line Level 4 27th April 2011 02:07 AM
Preamp to go with an Arcam Delta290 power - do i need active, or will passive be ok? julian Analog Line Level 2 15th March 2011 04:42 PM
Passive preamp with UTC transformers jovan Swap Meet 4 6th November 2006 11:44 AM
Passive preamp with utc transformers jovan Tubes / Valves 13 17th May 2006 05:56 PM
