alps pot for passive volume control
Old 14th December 2016, 04:19 AM   #1
soundnovice is offline soundnovice
Default alps pot for passive volume control
please suggest a good model number for alps pot to use as a simple passive volume control. i am looking for two of them each to use in monoblock amps.
Old 14th December 2016, 04:34 AM   #2
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Go one of these for each mono, choose resistance (1kohm-100kohm) depending on the input impedance of your amp, which we don't know.
ALPS Potentiometer RK27111 mono 1K 5K 10K linear o logarithmic Rotary | eBay
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 14th December 2016, 05:37 AM   #3
Thanks George.
that brings me to next question. how to find out the input impedance of the amplifier. the specs page don't specify for my amplifier.
my source is fiio x3 1st gen player which has a line out of 1.5Vrms and output impedance is given as 107Ω (which is typical i guess).
Old 14th December 2016, 06:33 AM   #4
georgehifi's Avatar
What is this amp? model and brand?
You can measure it with an ohmmeter (when it's not plugged in and on) so long as it's not capacitor coupled.
And "output impedance is given as 107Ω" is not right.
Cheers George
Old 14th December 2016, 06:46 AM   #5
Norge 1000 Gold - Norge Audio
not sure if its capacitor coupled. will try to check with the manufacturer.
Old 14th December 2016, 07:14 AM   #6
georgehifi's Avatar
All I found
"Each amplifier features JFET inputs (for high input impedance)"
So get the 10kohm, that should do. 20kohm would be better if you can find it in a single.
Cheers George
Old 14th December 2016, 08:27 AM   #7
oh wait....my plan is to first get rid of stock preamp and replace it with passive volume control. sorry I didn't mention earlier.
sent an email to you regarding lightspeed attenuator. pls check email
Old 14th December 2016, 09:34 AM   #8
gigigirl is offline gigigirl
Default Alps Pots not the best (Cheap & Chearfull)
If you want to build a passive Pre then do not use an Alps Pot. They are OK for low-fi but there are a lot better sounding pots around.
Any Resistor based Vol Pot found on Ebay will easily out play an Alps pot.
If you want a standard type pot that sounds good, look to Noble around $70-00
Cheers and good hunting
Old 14th December 2016, 04:53 PM   #9
tansand is offline tansand
The volume knob on the front is a passive volume control, if you hit the 'tone defeat' you have the same thing..? It may well already have an alps RK27 in it..
Old 15th December 2016, 04:47 AM   #10
the tone defeat is this actually dont cutoff the preamp stage, but massively desensitizes it. i guess by using big resistor. all in all, its not a very high end design. but the power amp itself is a good and old proven design.
alps pot for passive volume controlHide this!Advertise here!
SIMPLE remote volume control with alps motorized pot ChopperCharles Tubes / Valves 23 3rd June 2016 03:13 PM
Alps pot - volume control Sansui BA5000 reverbus Parts 5 15th April 2016 09:40 PM
Help With Alps Volume Pot Noise JimOfOakCreek Tubes / Valves 3 30th April 2011 11:48 PM
HELP- Need ALPS 12mm pot; regular consumer-elex volume-control stuff dozer Parts 5 28th January 2009 01:31 AM
Remote Control ALPS pot jkeny Parts 10 30th April 2006 09:35 AM
