Opamp buffer @ active crossover input?
Old 17th December 2016, 11:11 AM   #11
R.I.P.
The current draw of an opamp is the datasheet figure for quiescent plus whatever you send to the output.
If you have very light loading and no capacitance to charge/discharge, then the output currents can be very small, leaving the quiescent current as the only significant load for the regulators.
But if you have some capacitance as a load and have lower load impedances, then these can become the dominant load that is passed back to the regulators.
A 10k load driven to 2Vac is only 0.3mVpk from alternate supply rails. Add on the same again for small parasitic capacitance and you have only added 0.6mApk to the quiescent load. Small beer.
But if you had a 2k load driven to 4Vac and significant capacitance, then you can easily have 3 to 4mApk to add to your quiescent values for each opamp.
If there is limited supply rail decoupling at each opamp, then much of those peak currents have to come from the low output impedance of the regulator.
regards Andrew T.
Opamp buffer @ active crossover input?Hide this!Advertise here!
opamp matching +/- input impedance necessary for buffer? HiFiNutNut Chip Amps 34 29th March 2018 01:48 AM
Opamp input buffer choices tfboy Analog Line Level 31 13th September 2015 11:36 AM
Opamp for active crossover Keruskerfuerst Parts 2 7th June 2007 06:57 PM
Tube differential input/buffer /w opamp output gainclone aletheian Chip Amps 2 23rd August 2005 07:36 AM
Best Opamp for an active crossover? ShinOBIWAN Digital Source 1 21st March 2005 03:08 AM
