Op-Amp Circuit Components: Any Ideas About This Circuit Section's Function? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th September 2016, 08:12 PM   #1
Travis Clarke's Avatar
Send a message via Yahoo to Travis Clarke
Default Op-Amp Circuit Components: Any Ideas About This Circuit Section's Function?
This is from a car audio amplifier schematic (Alpine MRP-F450), but I'm hoping you guys have seen this before. I haven't.
It's in the line-level input (isolation [ground loop breaking]) front stages.
In the schematic section highlighted, there is a diode bridge connected to the dual rail supply voltages. However, I've never seen this before and have not had any luck finding a technical explanation anywhere.
I'm assuming it's maintaining the virtual ground as the op amps are connected in such a manner, and marked with "0V". However I don't see why this would be beneficial or necessary.
Ideas? Comments?
Old 13th September 2016, 09:19 PM   #2
rayma is offline rayma  United States
That's a clamp (actually two clamps, one for each op amp), not a diode bridge.
They prevent the voltages at those two nodes (+ input of the op amps) from exceeding
either of the two voltages connected to the ends (+/- 14V). Each clamp works
in conjunction with its 560R.
Old 13th September 2016, 09:25 PM   #3
Ok, that's what I was thinking but given it's line-level, and speaker level inputs are in another section, it seemed odd for an op-amp circuit to have that. I'm not unfamiliar with clamp circuits but I don't recall seeing it other similar designs.
Thanks for the response.
Old 13th September 2016, 09:28 PM   #4
Ok, that makes sense and was what I was thinking but given it's line-level, and
speaker level inputs are in another section, it seemed odd for an op-amp circuit.
Some op amps are very unhappy if the input voltage exceeds the supply voltage, hence the clamp,
which keeps the input within 0.6V of the supply.
http://www.analog.com/library/analog...amp-input.html
http://www.analog.com/library/analog...46-02/ovp.html
Old 14th September 2016, 01:26 PM   #5
Some opamps have the diode clamps inside the package.
With all these clamps (internal and external) one must use preceding impedance to protect the diodes from damage if there is ever an event that requires clamping.
You can also use diode clamps between the +IN and -IN
For best performance these diode clamps should pass zero current when not triggered. Some transistors wired in diode mode perform better than real diodes in this clamping duty.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th September 2016, 01:30 PM   #6
I think I see what's going on in this case. The speaker level inputs are connected to the same line level input paths (scaled via resistors) and the clamps are to prevent excessively high speaker level voltages, not the line level.
Yes, I understand the clamp resistors are needed.
Summing Op-Amp circuit FastEddy Subwoofers 48 29th November 2015 04:50 PM
Best OP-amp for EQ circuit? neskor Analog Line Level 12 22nd November 2012 12:45 AM
a breakdown of the component part function for a tda7384 amp ic circuit? thebestofall007 Solid State 0 20th October 2011 03:14 AM
strange op-amp circuit kubeek Parts 23 15th October 2006 06:25 PM
Discrete op amp circuit NickC Solid State 11 19th August 2002 05:50 AM
Copyright Đ1999-2017 diyAudio
