Salas DCG3 preamp (line & headphone)
Old 5th February 2018, 12:03 PM   #2451
bambadoo is offline bambadoo  Norway
Using soekris dac myself together with dcg-3. Works like a charm. The dac has a unreleased potential with regards to digital filters IMO.
With good filters the dac is extremely good.
However:
Because the DAC integrated volume control destroys the pure DSD path
Dont understand that part.
Old 5th February 2018, 12:09 PM   #2452
fred sonnen is offline fred sonnen  Germany
volume controll is made in PCM. You have to leave pure DSD path. There for I would like to have the controll within the DCG-3.
Did that make sense?
Old 5th February 2018, 12:31 PM   #2453
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by bambadoo View Post
Using soekris dac myself together with dcg-3. Works like a charm. The dac has a unreleased potential with regards to digital filters IMO. With good filters the dac is extremely good.
True, its all in the filter codes. It's a chameleon.
Old 5th February 2018, 01:05 PM   #2454
Dimdim is offline Dimdim  Greece
The DAMs, being R-2R devices, need to convert DSD to PCM to make sound. Disabling the digital volume control will not help with that. There can be no "pure DSD path" with R-2R dacs.
http://www.dimdim.gr
Old 5th February 2018, 01:27 PM   #2455
massimo is offline massimo  Italy
Just saw your nice blog, DimDim... are you currently developing a nice pcb for Salas Shunt Reg 1.2R? Quite interesting.
End of OT
Old 5th February 2018, 03:54 PM   #2456
OK, thanks for that. That was not my understanding. I will ask there again.
end off toppic ;-)
Old 6th February 2018, 06:39 PM   #2457
Russellc is offline Russellc  United States
Received my chassis from Diyaudio a bit earlier than expected. It is rather large and has plenty of room. The rear panel is cut for IEC plug, the part I have would work, screw hole spacing is fine, but out line of part doesnt quite cover the entire hole, leaving some small corners exposed. The part for the precut power amp size Chassis from Diyaudio store contemplates a different sized part, too large as it also holds the fusing.
Is there a plug everyones been using that fits this cutout and includes switching as well?
I am looking at Mouser and Digikey as I type this...Thanks in advance to those who have located this part.
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 6th February 2018, 07:06 PM   #2458
bk856er is offline bk856er  United States
bk856er's Avatar
Deluxe case? Store has pn of IEC under rear panel accessory kit listing.
BK
Never mind - now notice you differentiated the power amp case. Darn phone display..,
Old 6th February 2018, 07:57 PM   #2459
BK
I know, after searching myself blind, I have come to the conclusion that there is not one that small that has a switch. I found some with a fuse, but none with switch. So, one more hole must be drilled. It would be nice if the store made it large enough to fit a switched one but thus is life. I really like the way they do the power amp size one with the built in switch.
Russellc
Old 6th February 2018, 08:00 PM   #2460
Once the power inlet is done and the power supply wiring to it done, can the power supply be tested with no load and not yet connected to the amp board?
Russellc
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
