Salas DCG3 preamp (line & headphone)
Old 3rd February 2018, 08:28 PM   #2431
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Good news
Old 3rd February 2018, 08:56 PM   #2432
arnd13 is offline arnd13  Germany
DCG-3 and DCSTB soldering was done the day over. Still have to wait for transformers and heatsink. But I found a transformator with 2x 19VAC in one of my electronic boxes :-)
I just tested the DCSTB (each side seperat) and have following voltage values without any load:
Side A
+ 17.49 V
- 17.46 V
Side B
+ 17.30 V
- 17.24 V
I'm thinking of finetuning. What do you think about finetuning ? Is it worth to match the voltages to max. difference of 10-30mV
Greetings
Arnd
Old 3rd February 2018, 09:45 PM   #2433
Salas's Avatar
No worth. This is single ended with forced bias current from a source on the negative rail side. When the positive rail side is little different or exactly the same it makes no difference to the bias and offset. Your voltages are extremely near within each side for random Led bars references by the way.
Old 3rd February 2018, 10:47 PM   #2434
Thanks for your reply, so I can leave it as it is.
I just ordered the chassis and a ladder volume control (a chinese one which will be pimped with reasonable resistors).
I had luck to get the same chassis as my dac, so the units will look familar.
Old 4th February 2018, 03:36 AM   #2435
nashbap is offline nashbap  United States
Originally Posted by Salas View Post
Yes its the same as BC32740BU but with "cowboy legs"
Thanks.
F5TV3, AVC, BA3b pre, Salas DCG3b
Old 4th February 2018, 03:48 AM   #2436
rhythmsandy is offline rhythmsandy
Hi all, this thread is about a JFET & MOSFET preamp I am cooking for sometime now. Its two stage single ended Class A circuit.
It was developed on the bench involving much experimentation with topology and a range of active parts. Simulations came second.
Some speakers are insensitive, some amps also, or a source is relatively low output like a phono stage. So a line preamp with gain is good to have.
Its named DCG3 because it has DC servo and three MOSFETS. Its standard gain setting is also times three.
The main schematic is attached* Click for circuit description
Some THD plots when driving 1.5kOhm line input and various headphones are also attached.
*(12 Oct 2016 updated and build guide/bom pdf added)
erratum: C6,C7 should read 4x in the BOM. J3 in preamp's schematic is named Q5 on the actual board.
About J3/Q5 possible tolerances read post#452
what is the use of VR1?
Old 4th February 2018, 05:43 AM   #2437
Salas's Avatar
Nominal resistance is one thing. That's what the source sees. But ask them for one with no more than 5K output resistance. Else the preamp will slow down its rise time to more than its meant to be.
Old 4th February 2018, 05:45 AM   #2438
Salas's Avatar
Offset minimizing before putting the servo chip in the socket
Old 4th February 2018, 06:33 AM   #2439
Thanks for the hint. Probably the chines ladders use a circuit as described here:
Logarithmic Attenuator Calculator
With changing the wiring of the chinese ladder at the first relais it must be possible to get a constant output resistance.
Old 4th February 2018, 07:27 AM   #2440
Salas's Avatar
You can even fine tune the ladder's Zout to your liking regarding its audible effect on the preamp's bandwidth and rise time.
When different PSU, special non conventional series pot, changes in electrolytics values, etc. are tried, the preamp may change behavior from subtly to much out of its standard build character. This is a double edged sword. Could either help or hurt. The expert DIYer can evaluate and control parameters to only benefit though.
Also the uPA NEC monolithic JFET flat packs must be measured genuine for IDSS and curves if their sourcing is doubtful. Main clue: There is a number printed on them starting with a letter. That's their IDSS classification letter. If they fall out of their intended range they are suspicious. Don't use them.
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
