Salas DCG3 preamp (line & headphone)
Old Today, 03:24 AM   #2321
Russellc is offline Russellc  United States
Thanks for the responses. I think I will go high with the bias, and think about a switchable gain giving me two positions. The sockets are tight and were recommended for Pearl 2 resistor changes. Not very elegant, I will explore some sort of switching...for the gain.
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old Today, 03:25 AM   #2322
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Hikari1 View Post
And with 25ohm headphones you want as much current as you can get.
He will get 118dB SPL peak before negative sinewave clipping with 150mA bias on those cans. If he wants 120dB he will have to bias at 180mA.
Old Today, 03:28 AM   #2323
Salas's Avatar
Russellc
Maybe a DIP switch and a couple of resistors on a thumb sized board directly to the R6 pads. Don't ever switch the gain when powered on. Also test that the offset is good on all gains.
Old Today, 03:29 AM   #2324
Originally Posted by Salas View Post
*BTW I extrapolated the Nighthawk's 1V RMS sensitivity from an Innerfidelity's mesurements sheet I found online. There it took 0.098V RMS to reach 90dB SPL calibrated. Because 20log 0.098V is minus 20dB to 1V then 90+20=110dB SPL/V
I know they have in mind driving it with their Dragonfly DAC, so I figured they were plenty sensitive. BTW, I have both the original Dragonfly as well as the newer Red Dragonfly. Storing my CDS on the laptop and utilizing a free "MusicBee" software (which allows by passing the microsoft sound stack of mess and use of a WASAPI output), sounds way better than it has any right to, given the price
Russellc
Old Today, 03:35 AM   #2325
Salas's Avatar
I have listened to the original Dragonfly at a friend's computer room driving JBL LSR305 active speakers with SE to PseudoBAL cables. Not bad.
Old Today, 06:53 AM   #2326
MagicBus is offline MagicBus  Greece
Originally Posted by rhythmsandy View Post
the above diagram has only balanced in balanced out, SE in SE out but not BAL In SE out.
All you have to do is connect a balanced source at the input XLR and take SE output at the RCA. This will be one phase (positive or negative). The other phase will simply stay dissconnected.
Old Today, 07:01 AM   #2327
Perhaps it should be made clear that it's not a differential configuration. We are not talking about CMRR here. It's only a four rail line stage to amplify a weak balanced signal for the requirements of the next stage. CMRR will hopefuly take place there (the amp) provided it has differential input.
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 07:19 PM
Correct way to split line level inside dual headphone amp Seggelke Analog Line Level 6 7th September 2014 03:25 PM
Glassware Janus Shunt or regulated B+ (like Salas) for tube headphone amp? dludingt Power Supplies 0 21st April 2014 01:28 PM
FS: Crown Straight Line 2 Preamp, Power Line 4 Amp, FM 3 Tuner (SL-2, PL-4, FM-3) spitz Swap Meet 1 25th August 2013 12:01 AM
line stage + headphone amp then_dude Headphone Systems 0 2nd July 2006 10:17 PM
