Salas DCG3 preamp (line & headphone)
Old 2nd December 2017, 10:37 AM   #2271
beardman is offline beardman  Denmark
i will not be using the DCSTB supply...i have a supply from Newclassd
i will just use some smaller value,,,have other in same serie
Old 2nd December 2017, 10:40 AM   #2272
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its a good audio capacitors series and their 85C rating isn't a problem where they are located.
Old 2nd December 2017, 10:48 AM   #2273
Salas's Avatar
Newclassd recommends 100uF also by the way
http://www.newclassd.com/tpi.pdf
Old 2nd December 2017, 10:54 AM   #2274
yes ,i have forgot this from his paper
my supply is his UWB regulator,,because i like the sound from them..and the can deliver all the power i need
for now i must just wait to get the board,,will take some weeks
Old 15th December 2017, 05:46 PM   #2275
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Salas ...
Thank's for the preamp i build ~1 year ago
Still the best, and still playing everyday!
Nothing more, nothing less to say, thanks man
Rgds; Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 15th December 2017, 09:39 PM   #2276
Salas's Avatar
Nice
Old 16th December 2017, 07:17 AM   #2277
bambadoo is offline bambadoo  Norway
Yes - it truly is a great piece of design and audio equipment.
Old 22nd December 2017, 07:53 AM   #2278
Salas's Avatar
Originally Posted by Algar_emi View Post
Hi Salas. So here the latest results for the noise floor. As suggested I took my measurement with volume at mid-course, net effect was to see a higher 60Hz component, but reduced higher harmonics. Input is grounded.
Red trace is with case fully enclosed, Green trace is with volume pot ground pins connected to frame through a 10R resistor, it is slightly lower, but still is the better result ever I had. Now the noise floor is at -97dBV, instead of -95dB when I started.
Compare to your own measurement, I can see your using a laptop, probably running on battery. My own CLIO card is inside a PC, its power supply running off an insulated power transformer, so it is probably collecting nasty RF noise that reflects into my measurements. It is still one of the best results I had so far with my test setup.
Thanks for the tip.
Another possibly good tip is try BC327-40 matched transistors in the mirror instead of the matched BC560Cs as they are lower noise pin compatible types with still high enough hfe. They can improve the preamp's input referred noise by 4nVrtHz theoretically. As much effect as adding substantial degeneration to the mirror but intrinsically so. They are bit slower on the other hand but not so much so as to risk stability I would think. Can they even offer more subjective detail because they are quieter? I don't know, I haven't done that replacement, I just simulated it.
Old 15th January 2018, 01:22 AM   #2279
fredlock is offline fredlock  United States
What kind of head phone 1/4 jack terminal you guys using? Is this good enough? NYS230 REAN / Neutrik | Mouser
Old 15th January 2018, 01:45 AM   #2280
Salas's Avatar
I used that one. Its reliable. Another popular kind is the red button pro one with the size and mounting of an XLR but its a bit of hard push to unlock.
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
