Salas DCG3 preamp (line & headphone)
Old 7th September 2016, 03:20 PM   #11
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by merlin el mago View Post
What about the SQ?
Does not sound like an ordinary preamp. Sounds like a big class A power amp.
Old 7th September 2016, 03:21 PM   #12
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Interesting.
Old 7th September 2016, 03:23 PM   #13
What's the reason you make SS in place of tube?
Old 7th September 2016, 03:38 PM   #14
Salas's Avatar
I had those uPA NEC monolithic JFET flatpacks that had very nice curve matching consistency and I wanted to test ideas around them. So I beavered away for one and a half months and there it was. But I tested everything I had, even LND150 mini MOSFETS. The board has LSK389 positions too because not NOS. Closest to uPA THD profile. But uPA are still cheap and available because nobody uses them.
Has a sound smooth as tubes no worries. But combining resolution better than DCB1 even. See how it goes second harmonic as the load gets heavier in the THD attachments. Its the single ended output stage MOSFET nature. 100-150mA bias and virtually zero Ohm output impedance gives bass slam and definition too.
The headphones sound easily more alive bigger and smoother than they did on my Benchmark DAC1. Swiss knife preamp.
Old 7th September 2016, 03:44 PM   #15
Have you compared vs tube headphones �� amp?
Old 7th September 2016, 03:47 PM   #16
Salas's Avatar
I have compared vs various tube and SS line preamps
Old 7th September 2016, 04:00 PM   #17
Salas's Avatar
Here is IMD SMPTE when driving 120 Ohm for instance. That's strong 250Hz trying to modulate quieter 8kHZ. See the little bass tone modulations around the high tone's base. 0.0027% modulation at 101dB SPL with those AKG. Means clarity in busy music. Not easy to do that with SE tube headphone amp.
Old 7th September 2016, 07:17 PM   #18
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Great job Nikos!.
Great job like always...
Titan 2000 ,Cressendo Millenium 2000, P3A ,VSSA ΤΟ3 ,B1 Buffer ,Golmund Mimesis 9.2 Clone ,Preamplifier Dispre 2 - JFET, DCB1 SALAS, D-Reflector, BibFet, Buffalo II,ES9018K2M, Arduino LDR Volume, AK4490 Discrete Mirand Audio,SSHV2, 6V6 Salas Preamp.
Old 7th September 2016, 07:22 PM   #19
Salas's Avatar
Old 7th September 2016, 07:35 PM   #20
Salas's Avatar
Some oscilloscope shots. Bandwidth is 1MHZ with 20kOhm pot at middle value (worst case situation)
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
