Salas DCG3 preamp (line & headphone)
Old 28th February 2017, 11:01 AM   #1471
MagicBus is online now MagicBus  Greece
MagicBus's Avatar
Agreed. That's why I think XLR pin 1 sould be connected to circuit GND in this case. I'll test it against pin 1 connected to chassis as soon as I find some time.
Old 28th February 2017, 11:26 AM   #1472
bkdog is offline bkdog
XLR pin 1 must be connected to the chassis by the shortest route. Please do a search for "pin 1 problem". I think Rane had a decent analysis of the issues when I last looked.
Old 28th February 2017, 11:28 AM   #1473
ivigueras is offline ivigueras  Spain
ivigueras's Avatar
Hello!
Salas, I'm thinking about to try some better resistors like Shinkoh that I like very much in my DCB1, but are expensive. What resistors do you think are more critical in the signal path? (R1, R15 and RZJ, evidently)
Thanks!
Ignacio.
Old 28th February 2017, 11:34 AM   #1474
MagicBus's Avatar
This is true for differential amps. Here we have two indepented lines that do not amplify the difference of the signals applied in their inputs but just amplify the antiphase signals they get from the source. In differential amps the circuit ground stays out of the line. In the application discussed here the circuit ground is the returning path af the signal as with all SE circuits
Old 28th February 2017, 01:09 PM   #1475
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by ivigueras View Post
Hello!
Thanks!
Ignacio.
R6, R7 (feedback) for sure are important
R4, R5 (gate stoppers) are in the signal path also
Old 28th February 2017, 01:24 PM   #1476
Salas's Avatar
Can alternatively lift from GND and connect the phase channel amps R7 feedback returns together
Old 28th February 2017, 02:18 PM   #1477
nashbap is offline nashbap  United States
2) You will only need one CL60 per DCG3 board. It could be connected like my ground lifters - the rectifier bridge with the power resistor and the cap.
Thanks for responding Kostas.
So is your SLB connected to the DCSTB G point? I see that it is next to it.
nash
F5TV3, AVC, BA3b pre, Salas DCG3b
Old 28th February 2017, 02:25 PM   #1478
Kostas, I thought that you mentioned that you had a balanced connection going into your DCG3 from your DAC. In which case you should have signal between pins 2 and 3 only, not between pin 2 and pin1 and pin 3 and pin 1, since pin 1 is only the shield. I am referring to the XLR plug that plugs into the XLR connector of the DCG3.
nash
Old 28th February 2017, 04:51 PM   #1479
MagicBus's Avatar
Yes, I ought to test this at some point. It would change the way I can connect DCG3 for balanced or SE mode though.
nash
SLB is connected midway to the wire from DCG3 to DCSTB
nash
DAC output is balanced but circuit GND is connected to chassis by default and consequently so is pin 1 coming out from it though I suspect the sound card incorporates some kind of SLB too. Pin 2 and 3 carry the signal. Typical so far. Now, DCG3 input pin 1 could be connected to chassis or circuit GND without altering the grounding scheme of the DAC - sound card. Actually, when DCG3 runs on balanced mode it doesn't need the SLBs. It needs them only in SE mode. But even in balanced mode - if we don't do the R7 modification - DCG3 works in SE mode and then pin 1 is in the circuit.
Old 28th February 2017, 06:24 PM   #1480
ernesternest is offline ernesternest  Europe
ernesternest's Avatar
Hello Salas, hello Tea, another DCG3 running :-)
Thank you both and all the other guys too for their questions which prevented me from asking ;-)
Here my build still in workshop running on 130 mA and 6mV DC at output without the service.
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
