Need finding simple high impedance pre-amp to boost signal to Schmitt Trigger circuit - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th August 2016, 04:49 AM   #1
sberry is offline sberry  Australia
Default Need finding simple high impedance pre-amp to boost signal to Schmitt Trigger circuit
Hi there from a fairly unskilled (electronics wise) muso needing some help getting a few circuits right for a new project.
My project involves numerous triggers driven from my guitar, various drums and other instruments using simple piezo transducers as the pickups. From the trigger instruments the signals do various things such as acting as key inputs for gates and driving voltage controlled synth arppegiators and things the like that via a Schmitt Trigger circuit using a 555 IC. (see that circuit below).
What I need is a simple pre-amp circuit (with a variable output) so I can get the right level for each trigger signal's assigned task. Each instrument supplying the trigger has different output levels, and drummers hit with different velocities for example, so I'd like something easy to make that can run just behind the trigger and be adjusted to provide just the right level for the schmitt trigger or other application that I'm sending the trigger to. If I use a little mixer to test how much gain I need it seems to be a range of about up to +60 db. I'd also like to be able to turn it down to zero signal or attenuate the output downwards if necessary.
A secondary requirement if it's easy enough would be a pot that can shape the trigger input envelope such that I can adjust the threshold for signal cut off. That way if the trigger is coming from a hi-hat for example, I can make it a steep cut off envelope which would allow the drummer to open the high hat and let it ring while still only supplying the trigger with the initial hit. Also some of the triggers controlling various gates will be driven by vocals so I might want to extend the envelope to enable a longer gate open threshold.
So sound quality as per guitar signals isn't really an issue - just looking for clarity of signal-on and signal-off, ideally with the input amplitude envelope control plus variable output described above.
So I'm hoping there's a good simple and cheap circuit someone can suggest for me - I'm going to need to build a fair few of them for this project so a simple quick build and cheap cost is also a must!
Many thanks in advance!!
Old 10th August 2016, 07:29 AM   #2
Zero D is offline Zero D  United Kingdom
Hi, do you need the output from the 555 to just trigger once each time it's input reaches the required above threshold voltage from the preamp, or ?
Rice Kellog still going strong Not sent from a SpyPhone with CrapApps etc
Old 10th August 2016, 11:59 AM   #3
Yep - just one pulse at the 555 output per trigger input spike is all I need. I have it working already as per the circuit I posted, but I have to hit the piezo trigger too hard to get the output pulse. If I go through my little Mackie mixer on the way in and boost the signal about 30-40db it has the right "action" in terms of trigger dynamics - so I'm looking for a simple circuit to do the same thing (including a variable output so I can set the output level exactly for various trigger strengths at input).
The bonus feature if it's easy would be that I could adjust the envelope of the trigger input that is fed through the system so I can gain a single trigger from a "transient plus ringing signal" input such as an open hi-hat. In that case all I want is the transient to go over the threshold so I'd like to be able to "shape the way the input is driving the 555 circuit. Maybe variable ouput is enough to achieve that?
What I didn't add is that for the particular application that is using vocals as the trigger I would be going directly to a gate key input and not the 555 circuit. The gate itself has threshold, attack and release settings so maybe having that second feature is not necessary. If the signal is strong enough at the output from the vox input I can just set the release on the gate to hold open for longer and that would achieve the desired effect.
However, for the Piezo signal input I would love to have the amplitude envelope component included so I can get a spike from the initial transient and nothing as the hi hat continues to ring. Then the next time it's hit I'd get another spike.
So in thinking about it more - (always worth thinking more before posting as it turns out!) the main request is for 1. A mic level input circut outputting -infinity to +60db gain, and 2. a high impedence (Piezo transducer signal) input circuit outputting -infinity to +60 output, WITH an input amplitude envelope adjustment if possible! Hope that makes sense!
Old 10th August 2016, 05:16 PM   #4
indianajo's Avatar
I'd use an op amp for variable gain. Fixed stable gain, no temperature effects of set point. 4558 are cheap and univerally available. If you capacitor couple the input signal and bias the op amp input with a couple of resistors somewhere in the middle of the supply, you don't need the traditional +-15 v supply. I'm using an 18 v race car wall transformer for my mixer. A pot to turn down the input, Rf about 10 x Ri for a gain of about 10, what's not to like.
I think 555 are a bit obsolete now we have fets. I'm using 2n7000 nfets as timing components, trigger about 5 v on the gate. If you have plenty of drive current for the gate, (like from an op amp output) salvage nfets from blown up switcher supplies would work, too. I find those things on the curb all the time - about 100 fets in a blown 50" LED TV two weeks ago. Delay happens when gate goes low and capacitor charges up. If you need and edge trigger, capacitor couple the gate to the source. Bad fets, if you short gate & drain, the source is usually 0 ohms to the drain too. Good ones, infinity ohms.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 10th August 2016, 05:49 PM   #5
Perhaps
_
Old 10th August 2016, 06:21 PM   #6
Here's a PreAmp circuit that should work for both audio inputs. The only difference is the value of the Potentiometers, & the input Resistors/Capacitors.
For the Mic PreAmp Ra = 10k Ohm. For the Piezo PreAmp Ra = 1M Ohm
For the Mic PreAmp Ca = 0.22uf. For the Piezo PreAmp Ca = 0.0022uf
For the Mic PreAmp the Potentiometer = 47k Ohm. For the Piezo PreAmp the Potentiometer = 1M Ohm
The Potentiometers give a variation between zero gain & full gain. The values, along with the 1k resistor, should give enough level to trigger the 555.
I suggest a 12V Power supply to feed both circuits.
You might like try experimenting with the 555 to increase the pulse length output time. In the meantime, try the PreAmp circuits.
Old 10th August 2016, 11:14 PM   #7
Thanks for all the suggestions everyone - Zero D, is that op amp in the circuit a 4558 as suggested by indianajo? I like the look of your circuit as it's simple and I should be able to build a few of them fairly easily. Question though - I'm running the 555 circuit on a 9v battery, and can get it to fire with even with only a direct signal from striking the piezo fairly hard. So I don't think I require a huge voltage output from the pre-amp, just more than I've got at the moment. Also since the 555 input trigger needs to be a certain threshold below the power supply itself for the 555 to fire, could I use a 4.5v power supply on the preamp circuit you supplied and still achieve the desired result? I want to avoid bulky powersupplies and extra power leads for now if possible.
Old 11th August 2016, 05:24 AM   #8
The OpAmp/s ideally should be a FET type for high impedance inputs such as Piezo's, eg TL071/72/74 range, which are inexpensive. But the ones for the Mic's could be for eg, 5532 type which are also inexpensive. The 4558 doesn't have enough gain/bandwith for the up to 60db gain you requested ! Whichever ones you use, make Sure they are "Unity gain stable" The above i suggested are. Don't forget to apply the usual 0.1uf Caps across the Opamp supply pins. A correction on the pot values, they are the other way round, i mistyped ! For the Mic PreAmp the Potentiometer = 1M Ohm. For the Piezo PreAmp the Potentiometer = 47k Ohm
If you can trigger the 555 directly from the Piezo, then it's putting out more voltage than i estimated ! In which case you could make that Pot = 4.7k Ohm
I wouldn't recommend less than a 9V DC supply. The one PS could supply ALL the 555's & OpAmps. I showed the supply connected like that ! Also, you would Only need one set of components for the Mid point supply = 1/2 Vcc to feed All the OpAmps.
Old 11th August 2016, 09:30 AM   #9
Great - thanks for that followup Zero D - I'll go with that, and can see how I can put the preamp and the 555 circuit in the same unit sharing the one PS, which is certainly ideal. I'll make the input a switching one to cut power when it's not plugged in and all should be sweet. I'll patch it all up next week on a breadboard to check out how the two circuits operate together, and will follow up with a post here once I've tried it out. Thanks for the circuit and advice!
Old 11th August 2016, 01:17 PM   #10
Taking another look at it, i Would include a 3.3uf Cap as shown, in EACH of the 1k legs to 1/2 Vcc. This will prevent excess DC offset on the OpAmp outputs.
Mic pre strange high-freq boost (what is broken here?) sobukus Analog Line Level 7 22nd August 2012 08:16 AM
Simple Pre-Amp with Variable High-Pass - This right? domjohnson Analog Line Level 11 11th January 2012 05:58 PM
Very Simple Low and High Pass Pre-Amp Filters Help houndazs Solid State 7 11th July 2011 06:46 PM
simple bass boost circuit deepanger Solid State 11 28th December 2002 02:37 PM
Remote trigger circuit for amp Gaber Solid State 7 1st February 2002 06:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
