Mark Levinson 380s PreAmp Schematic needed
Old 21st May 2016, 11:01 PM   #11
ammel68 is offline ammel68  United States
Banned
Originally Posted by Hans Polak View Post
Here it is
Hans
Thank you! Since the MAT01 and 02 are still available, I may try to layout a board and see how this buffer circuit sounds.
Old 22nd May 2016, 05:46 AM   #12
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by mgkman View Post
seemingly random rapid relay clicks and varying odd characters on the display
There is a pretty good chance the processor/rom are cooked and only ML can fix that. Instead of having random technicians poke inside why don't you send it to the factory?
A good technician can reach a diagnosis quickly but a poor one can do plenty of damage. Worth taking the risk?
Old 22nd May 2016, 10:19 AM   #13
Hans Polak is offline Hans Polak  Netherlands
A good advice, thatīs the only thing to do that makes sense.
Hans
Old 22nd May 2016, 12:28 PM   #14
mgkman is offline mgkman  United States
Thanks for the reply. ML no longer services in house. The three authorized shops in the US all get mixed reviews. So I'm torn on where to send it.
Old 28th August 2016, 09:03 AM   #15
Unfortunately, there was a 15K resistor missing between the two darlingtons.
I have put the model in LTSpice, and here are the results, Bode diagram and distortion figures at 1k, 3k, 10k and 20 kHz.
Notice that the 100pF in the previous diagram was adjusted here to 860pF for the best results.
However, components differ a bit, but in the final build version, you will have to twiddle with this cap with the help of a 10kHz square wave to get the best results.
Hans
Old 8th October 2016, 11:01 AM   #16
jonstanza is offline jonstanza  Portugal
jonstanza's Avatar
Hello, I am trying to troubleshoot a startup problem on my ML 380s Preamp. Can anyone provide a service manual and/or schematic?
Mgkman...
What is the part of the manual you need?
Old 27th March 2018, 07:48 AM   #17
sunil_1972 is offline sunil_1972
could you confirm which series resistor replace in 380s to upgrade
Old 16th April 2018, 01:41 PM   #18
E300d is offline E300d
Default Mark Levinson 380 NO audio on the left channel
Hi, I am a new member and I need any one can help me out. I had a Mark Levinson 380 and no audio on the left channel. Please any one out there have the schematic 380, 380s or any ideas can help me out. I really appreciated.
Thanks,
Bruce
Old 17th April 2018, 02:35 AM   #19
Lbud4 is offline Lbud4  United States
Default Mark Levinson 380s PreAmp Schematic needed
The schematic for the 38 is easily available. Just search google and you will find it. The 380 is built on the same circuit board. There are a few parts changes — some documented above. I have heard of a similar problem with a 38. In that case one of the 74HC4094 shift registers that control the dac volume control had failed and thus no signal through the dac. I would first verify rail voltage. Have the electrolytic caps been replaced? Next I would follow the signal path from input to output and see where it stops.
Old 19th April 2018, 10:25 PM   #20
Thanks for the information ML38 schematic.
Bruce
Mark Levinson 380s PreAmp Schematic neededHide this!Advertise here!
equalizer with a pre Mark Levinson No. 380s audiophile.1963 Solid State 1 22nd May 2016 12:22 PM
Mark Levinson 380S EPROM code willcycle Solid State 0 25th August 2014 09:13 PM
Levinson 380s Preamp on the FRITZ! GRRR! chucker Parts 1 13th January 2012 10:36 PM
Mark Levinson ML1 Preamp Schematic thermionic Solid State 3 25th February 2009 11:26 PM
Mark Levinson 380S Sunsun22 Solid State 10 19th March 2006 08:16 PM
