My Borbely All-Fet Preamp with Subbu
Old 8th February 2018, 12:18 PM   #41
merlin el mago is offline merlin el mago
merlin el mago's Avatar
If I remember well Les Bordelon was an autorized dealer of Erno Borbely.
Old 8th February 2018, 12:22 PM   #42
kannan_s is offline kannan_s  United States
Send a message via Yahoo to kannan_s
Originally Posted by janegood View Post
Les Bordelon now sells his own designs, inspired by Borbely I think, and this probably eliminates the problem of sourcing legacy Toshiba devices.
do you have any link to find out his offerings?
Old 8th February 2018, 12:27 PM   #43
janegood is offline janegood  South Africa
info@LBAudioSystems.com
Les Bordelon [lbordelon@roadrunner.com]
Old 8th February 2018, 12:29 PM   #44
LBAudio Systems - Home
Old 8th February 2018, 12:29 PM   #45
Correct
Old 8th February 2018, 12:34 PM   #46
Default Remote volume control for "Borbely/Bordelon" preamp
Anyone with experience of the Crystal CS3310 and the TI PGA 2310, using the IRVC chip from TaunTek Home Page ?
Old 8th February 2018, 05:07 PM   #47
ticknpop is offline ticknpop  Canada
Actually all of Les’s products use the same Toshibas ( or substitutes if he has to, but not as good as the preffered Toshibas).
Old 10th February 2018, 11:12 PM   #48
phase is offline phase  United States
Nice project you have, those Borbely parts were a great find, Iíll bet it sounds good.
I am gathering the components for a similar build that will use an SD memory card reader to a dac, then a version of a JC2 line driver.
Old 1st March 2018, 01:16 PM   #49
Originally Posted by ticknpop View Post
SB it seems a shame to AC couple the Borbely preamp through an electrolytic cap. The Borbely system I run is totally DC coupled all fet/jfet from dac or phono input to power amp output. The power amp uses Borbelyís dc protect / mute delay board for DC protection - the protection board design is in the Borbely DC 102 article. If you want to protect the preamp output from DC output and avoid any capacitor coupling you can use the DC 102 protect board and make it more sensitive by adjusting the reference voltage setting resistors to maybe 10 to 50mv. It also gives you a mute delay for turn on.
Donít increase the value of any of the power suppy Electrolytic capacitors on the DC 102 DC protect board like any diyaudio guy would normally do. The cap values are delibereratly small so it turns off (mutes) right away when the preamp is turned off or the AC power fails. The input to the protect board can be a 10uf /63 volt polyester instead of the back to back 22uf/40 volt electrolytics.
Updates to the preamp design are to use OPA 140 or AD 4625 op amps for the servo. They have 1/5 or less than the noise of the AD 820. Replace the 33K2 current source resistor for the VAS cascode with a E102 jfet current source diode. Replace the VAS cascodeís LM385 voltage references with 2 series connected green LEDs ( not blue ones like Erno first used, they are too noisey).
AD 4625 op amps exist?
Old 3rd March 2018, 12:25 AM   #50
The ADA 4522 is a better chip to use for servos.
My Borbely All-Fet Preamp with SubbuHide this!Advertise here!
Borbely Fet Follower / HarryHaller? transducer Solid State 172 13th July 2004 05:21 AM
Views on Borbely All Fet Monoblocks smithy666 Solid State 1 13th June 2001 03:22 PM
