High Offset with AD8065/66. - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 5th November 2015, 04:15 AM   #1
ammel68 is offline ammel68  United States
Default High Offset with AD8065/66.
Every time I try using the AD8065/66 within the feedback loop of another op-amp or buffer, I get .5V or more offset at the outputs.
If I use it alone the offset is quite low.
Being this a FET part with low input bias currents, the high offset is a complete mystery to me.
Can someone explain why the this particular chip isn't happy inside a global feedback loop?
Thanks...
Old 5th November 2015, 04:35 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Its a rather high bandwidth part - perhaps your 'offset' is in fact oscillation. To use it with a buffer, that buffer would need to contribute negligible phase shift itself.
Take a look at the OL gain/phase plot. The zero crossing is around 65MHz where there's a phase margin of ~50deg. Then consider say the BUF634's phase response at the same frequency - its about 50deg at 25oC, getting worse at higher temps. A recipe for oscillation at unity gain for sure. That's with the BUF634 in wideband mode, in low Iq mode there's absolutely no hope of stability except at impractically high gain.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 5th November 2015, 08:27 AM   #3
...or when draining away some open-loop gain, for that matter.
Old 5th November 2015, 04:57 PM   #4
Interesting...I had no idea about the phase shift issue.
I have found most, but certainly not all, FET op-amps work okay inside a feedback loop.
I typically use the 8065/66 with a gain of 3.
Thank you for the replies.
Old 5th November 2015, 07:00 PM   #5
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Can you post a circuit. Should be an easy one to fix.
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 6th November 2015, 02:39 AM   #6
Sure, I was trying to use it in place of the AD744 in this circuit.
Old 6th November 2015, 02:46 AM   #7
abraxalito's Avatar
Can't see an OL transresistance/phase plot for the AD811 so it won't be an easy one to predict.
Old 6th November 2015, 04:13 AM   #8
What exactly are you trying to predict?
I've tried the AD8065 in place of the 744 and there is considerable offset at the outputs.
Old 6th November 2015, 04:17 AM   #9
abraxalito's Avatar
Whether the combination is likely to be stable, and if so, over what range of gains.
Old 6th November 2015, 06:15 AM   #10
Bonsai's Avatar
Put a small Capp - say 22 pF between pins 2 and 5.
Secondly, make sure you have Rs fitted close to U2.
All your feedbzck connections need to be really short with composite amps like this - any stray capacitance from the - inputs to ground or the rails will cause problems.
To get your circuit going, I would consider starting off with the AD744 as shown in your circuit.
bonsai
Looking for response curve of Philips AD8065/M8 nghoanglong Full Range 4 26th February 2014 12:35 PM
Ad8065 Rotellian Digital Source 49 5th December 2011 05:26 AM
High offset drift darkfenriz Solid State 11 4th February 2006 09:35 AM
High DC-Offset - Why? rampage101 Chip Amps 1 30th April 2004 08:16 AM
Marantz CD67/AD8065 upgrade goes 'well' dantwomey Digital Source 12 22nd November 2003 08:56 AM
Copyright 1999-2017 diyAudio
