BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
It was done with remote sense, here are the pictures
Thank you for your answer, i will maybe take this route when i rebuild mine in a proper case. Meanwell have a psu block that output +-15v and 5v. The +-15v for the BPBP is ok, but the 5v for my maya controller is not enough, or i will need to bypass the maya psu to feed directly the 5v to the board.
I have a question,
I'm thinking of making this preamplifier, what are the experiences of people who have made it?
Can I make a parallel output (XLR and SE) and connect the amplifier to the XLR and the subwoofer to the RCA, or do I have to make a balanced to SE conversion on the SW output?
And how can I limit it so that it does not exceed +16.6dBu
Have another look at the circuit diagram and you will see that the output is not differential, but made balanced by inserting a resistor in the gnd line of equal value as in the hot line.
An SE output would mean to tap the ground line right before this resistor.
Hans
