BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
Old 8th September 2015, 02:59 PM   #21
jcx is offline jcx  United States
I would’ve used the Whitlock’s input chips and implemented the capacitive bootstrap technique as well, except that the distortion performance is not good enough in my view.
just a statement of LM4562 linearity vs THAT chip designed decade earlier, undoubtedly on an a open fab process from that era
the bootstrapping shouldn't have any additional distortion consequence - in fact should reduce most of the cap's nonlinearity and DA effects for the common mode leaving even less to diff out
Old 8th September 2015, 03:01 PM   #22
R.I.P.
I did not see any limits on maximum gain, nor on maximum attenuation, achievable with the active gain block. Have I missed that?
Are there some limiting resistors built into the PCB?
regards Andrew T.
Old 8th September 2015, 03:09 PM   #23
Bertel is offline Bertel  Germany
Jan had pointed out that in fact there aren't any in the design, probably in order to not mess up the perfect tracking only dependent on rotation angle of the pot with both channels on the same spindle. There was an alternative approach which Jan had offered to share shortly.
Old 8th September 2015, 03:14 PM   #24
I see - that's indeed very interesting!
I suggest we keep track of potential design enhancements or variations for kind of a "version 2.0". Currently we have two already - Whitlock's diff amp input common mode bootstrapping, and alternatives to pot / limiting resistors
Old 8th September 2015, 04:07 PM   #25
Alright, I have set up an Excel Online sheet to collect current interest.
Please go to http://1drv.ms/1JPOfR6 , enter your username and the amount of 'bare' PCBs and/or fully built modules you are interested in. No obligation for now, just to collect an estimate on cost and volumes.
Thank you,
Robert
Old 8th September 2015, 05:12 PM   #26
av-trouvaille is offline av-trouvaille  Netherlands
+1
Old 8th September 2015, 05:57 PM   #27
BigE is offline BigE  Canada
BigE's Avatar
How many modules are needed for stereo?
Old 8th September 2015, 06:03 PM   #28
The modules are stereo, so one.
Old 8th September 2015, 08:52 PM   #29
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I am building a P - P with some small changes.
It should play tomorrow.
Lonesome but faster ....
Old 8th September 2015, 09:20 PM   #30
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Originally Posted by jan.didden View Post
BTW I had 1000 free boards which are all given out
Jan
Would be interesting (and probably impossible) to find out how many were build from that 1000 and how many are lingering in drawers.
BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)Hide this!Advertise here!
Bruno Putzey interview Zero D Solid State 5 30th May 2014 12:29 AM
Balanced Buffer Needed with a Balanced Volume Control? DualTriode Analog Line Level 5 9th September 2012 04:37 AM
Balanced Preamp with discrete solid state volume control. Dave Solid State 6 20th August 2004 09:17 PM
balanced volume control diy student Solid State 2 16th January 2002 12:23 AM
