BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)
Old 8th September 2015, 12:45 AM   #11
Pan is offline Pan  Sweden
Also, unbalanced in = ground one of the input buffer amps.
Unbalanced out, bypass R15/42 and use as GND.
Old 8th September 2015, 05:33 AM   #12
Bertel is offline Bertel  Germany
Default BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control...
Originally Posted by Joachim Gerhard View Post
I asume that there is also a posibility for unbal ( RCA ) In and unbal ( RCA ) Out.
Joachim, instead of using RCA connectors at the amp, would using cabling as sketched in Figure 6 in the article be possible in your application, with RCA at the source and XLR at the input, and vice versa? (Also described in 12.3.1 here: http://www.hypex.nl/component/weblin...datasheet.html )
Old 8th September 2015, 11:01 AM   #13
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Pan View Post
I wonder if J4/5 is simply there for letting your PCB layout software accepting a GND connection. Zero ohm resistor could be used as well.
It's mentioned in the text.
Correct. I think he calls it 'net-tie' points. CAD software often insists on connection anything with the same name together wherever IT thinks convenient. If you have two ground 'things' that you want to force to connect at a specific point, then depending on your CAD idiosyncrasies, you might be forced to do a workaround like Bruno did. Clearly explained in the (free) article - no excuse NOT to read it!
BTW I had 1000 free boards which are all given out but the Gerbers are available free on the website (under Downloads) so you can have made some yourself, or set up a group buy. It's a small board so not expensive, BUT it does challenge your SMD solder proficiency though. I managed to get two boards together with no mistakes.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 8th September 2015, 11:39 AM   #14
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
I'm short of round tuits at the moment, but if anyone is getting boards made I'd be in for a few to help get the costs down.
Old 8th September 2015, 11:50 AM   #15
Turbon is offline Turbon  Sweden
Turbon's Avatar
+1
Old 8th September 2015, 01:30 PM   #16
Many thanks Jan! I have a visual impairment and can't build myself, so I will have the PCB printed and built professionally.
I will try to figure out how to create an Excel Online sheet, so if anyone wants to join me with either a bare PCB or a completely built unit, please let me know. Will get quotes now and publish cost shortly.
Thanks,
Robert
Old 8th September 2015, 01:50 PM   #17
Turbon's Avatar
Hi there Robert.
I want to make my own misstakes so a bare board or two with an recommended BOM would be fantastic !
Old 8th September 2015, 02:39 PM   #18
jcx is offline jcx  United States
Putzeys' comment on the THAT Corp patent is dated - actually Whitlock's patent on diff amp input common mode bootstrapping is public domain now
http://www.google.com/patents/US5568561 coverage expired last winter with the most generous interpretation of term == filing date + 20yr
any new design could consider it without IP concerns
Old 8th September 2015, 02:44 PM   #19
Interesting point jcx, thanks!
Yet Bruno also writes (page 10):
I would’ve used the Whitlock’s input chips and implemented the capacitive bootstrap technique as well, except that the distortion performance is not good enough in my view.
Old 8th September 2015, 02:52 PM   #20
Fair enough Turbon
Bruno has a parts list in his article already, plus there's a more specific one with manufacturing codes in the Downloads section of Linear Audio website here: Downloads | Linear Audio (this is the direct URL to the BoM).
BPPBP - Bruno Putzey's Purist Balanced Preamp (well a balanced volume control really)Hide this!Advertise here!
Bruno Putzey interview Zero D Solid State 5 30th May 2014 12:29 AM
Balanced Buffer Needed with a Balanced Volume Control? DualTriode Analog Line Level 5 9th September 2012 04:37 AM
Balanced Preamp with discrete solid state volume control. Dave Solid State 6 20th August 2004 09:17 PM
balanced volume control diy student Solid State 2 16th January 2002 12:23 AM
