Arduino based LDR volume and source selection controller
Old 8th January 2018, 02:03 PM   #921
sorinv is offline sorinv  Romania
Thanks for the warning.
The headphone amp would be powered by a separate power supply, this is why I was asking about the power relay control on the LDR board. I'll just keep it powered on all the time anyway.
Old 5th February 2018, 07:22 AM   #922
zdr is offline zdr  Belgium
zdr's Avatar
I have one fully assembled and tested set for sale including power supply that can be adapted to US voltage, with the original PCB and BOM specs from Vincent, apart from 4x2 IO board which is smaller and does not switch the ground and therefore using only half of the relays. I can bundle it with OLED or LCD.
You would only need to add a box, power and RCA connectors.
Old 5th February 2018, 03:20 PM   #923
Joca is offline Joca  Portugal
need help
I have a AIO from Zdr and the 2004 LCD. I only have one input and output attached to the board. I made the calibration process but in the end my lcd doesnt respond to the controller input. it hangs. what could be the problem? My LDR values are LSE-100
LSH-125
RSE-73
RSH-99
Old 5th February 2018, 03:48 PM   #924
i have the "narrowing conversion" problem in the verification process but the code updates. The Lcd seems to be working in the calibration menu. Only the normal operation hangs after some 2 or 3 seconds of turn on.
Old 5th February 2018, 04:37 PM   #925
problem solved or at least i find it. If i touch the unpluged pins of the arduino nano (tx, Rx) with a feather pressure the lcd refresh nicely. So, i think it could be the absence of earth wire. will see and post.
Old 26th February 2018, 10:50 AM   #926
yurgs is offline yurgs
Default error 1 , error 2
i had great fun assembling the LDR cotroler and the powersupply.
i uploaded the Nano and it seems to work!
here are some pictures of my build.
Preamp - stereoscope
unfortunately i dont seem to be able to get it to calibrate.
i started with setting the bias, it seems rather difficult to adjust.
(when i switch to "bias Adjust" the Multimenter shows about 1mr, and it slowly goes down to 800k.) then i set it to 700k
i measured the res:
1: 100r
2: 161r
3: 114r
4: 195r
Voltage is 4.96V
after updating the code i started calibration but it finishes either with error 1 or error2
the bias always seems to drift.
am i doing something wrong here?
Thanks !
Lenco L75/ Jelco 750L/ Denon DL103 Shibata // Hypnotoad's AD797 Pre // LDR Arduino Controller // chocoholic's Liteamp // Prestigeous 2 Monitor
Old 3rd March 2018, 07:47 AM   #927
i have got Nebs AIO Board, and i used NSL-32SR3.
the Mosfets are FDV301N.
i checked Resistor Values for the Biasing circuit, they are ok.
Is changing the Optocouplers really the only thing left i can do here?
Any Help would be apreciated
thanks!
Old 3rd March 2018, 08:12 AM   #928
zdr's Avatar
thanks!
I believe it's written somewhere in the code comments that if any value is higher than 150, ldrs should be replaced.
Old 3rd March 2018, 08:15 AM   #929
Thanks for your reply,
i checked the code, it says
any value above 200r should be replaced.
maybe i have to order some in anyway..
Old 3rd March 2018, 08:24 AM   #930
zdr's Avatar
Make sure you don't have anything on the outputs and inputs while calibrating, and that you did not make any soldering mistakes. I would not change ldrs before everything is triple checked. Check all the resistor values around fets.
Arduino based LDR volume and source selection controllerHide this!Advertise here!
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 08:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 09:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 10:51 AM
LDR Based Input Selection udailey Analog Line Level 25 5th October 2011 10:03 PM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 01:50 AM
