Arduino based LDR volume and source selection controller
Old 7th November 2017, 06:21 AM   #901
yurgs is offline yurgs
Hello Sorin,
i just sent a mail to farnell since i ordered them 3 weeks ago and got told these will be availlable again next year. i got an answer and they told me they had a technical problem.
thanks for pointing it out!
i have all the other components apart from some resistors and the display,
cheers
J
Originally Posted by sorinv View Post
I just ordered that from farnell. They seem to have stock and you can order there the LDRs as well. Here are the links I used:
NSL-32SR2. - ADVANCED PHOTONIX - Optocoupler, Photocell / LDR Output, Axial, 4 Pins, 25 mA, 2 kV | Farnell element14
FDV301N - ON SEMICONDUCTOR - MOSFET Transistor, N Channel, 220 mA, 25 V, 3.1 ohm, 4.5 V, 850 mV | Farnell element14
These are in romanian, since I ordered from Romania, so you'll have to search for them in the german site. Or change the language?
Rest of the components I ordered from mouser. They offer free shipping I think over $60 or so. If you need a mouser order list, I have that for the V1 board - IO, PSU, CTRL (bought the boards a long time ago, never had time to get to assemble them).
Sorin
Lenco L75/ Jelco 750L/ Denon DL103 Shibata // Hypnotoad's AD797 Pre // LDR Arduino Controller // chocoholic's Liteamp // Prestigeous 2 Monitor
Old 7th November 2017, 08:02 PM   #902
zdr is offline zdr  Belgium
zdr's Avatar
RS Belgium has 5LN01C:
5LN01C-TB-E | ON Semiconductor 5LN01C-TB-E N-channel MOSFET, 100 mA, 50 V, 3-Pin CP | ON Semiconductor
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 8th November 2017, 01:36 AM   #903
jsantoro is offline jsantoro  United States
Or you can use the replacement for the 5LN01, VN2222LL-G and just bent the leads a bit. See pic:
Old 8th November 2017, 08:42 AM   #904
R.I.P.
RS in the UK have increased the cost by ~44% for the same 100off rate. And much higher if only 50off (+157%) are bought.
regards Andrew T.
Old 8th November 2017, 11:12 AM   #905
Thanks all the help,
Farnell sent the 5pcs. after they sorted out their "systemfault".
already soldered :-)
i might post some pics when i finished soldering
Old 16th November 2017, 07:44 AM   #906
ghiglie is offline ghiglie  Italy
Anyone tried a design with ESP8266 ?
Old 17th November 2017, 08:27 PM   #907
zdr's Avatar
You mean like, to design same thing from scratch on a totally different platform? I don't think so
Old 17th November 2017, 08:51 PM   #908
sorinv is offline sorinv  Romania
ESP8266 should be compatible with Arduino, with the added benefit of having wifi available as well. So potentially you could remotely operate it with your cell phone. I heard the wifi part is not that reliable though, but I have not tested myself.
Also, not sure how much memory it has available.
Old 17th November 2017, 08:52 PM   #909
It's not totally different, I could easily adapt your code. NodeMCU or weMOS are interesting for this use. I'd do myself, but I lack skills with PCB design.
Old 17th November 2017, 08:56 PM   #910
I use it for a pair of IoT projects. Not bad at all.
Arduino based LDR volume and source selection controllerHide this!Advertise here!
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 08:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 09:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 10:51 AM
LDR Based Input Selection udailey Analog Line Level 25 5th October 2011 10:03 PM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 01:50 AM
