Arduino based LDR volume and source selection controller
Old 27th September 2015, 08:12 AM   #21
wineds is offline wineds  Australia
Looking good! Please keep provision for the optical encoder. Otherwise my wife can't use it.
Old 27th September 2015, 12:59 PM   #22
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Instead of MOSFETs you can always use a diffamp as the current source. A part like the LT1990, INA154 (dual)
Silonex has an equation for fitting the response, or you can derive your own. In practice, you only need 3 points for a reasonable fit. You do have to measure, however, because the parts vary from piece to piece.
Old 27th September 2015, 06:51 PM   #23
jps1964 is offline jps1964  Germany
... the two first boards...
I will use the EA ASSEMBLY eDIP128B-6LWTP (touch, wake-up on I2C).
Old 27th September 2015, 07:41 PM   #24
Vincent77 is offline Vincent77  Europe
Vincent77's Avatar
Originally Posted by jps1964 View Post
Hello Vincent,
Ive only one objection in your design: the use of the chinese display; it is not really long term availability and for some people really hard to purchase.
My idea is to modify your design by adding a LCD touchscreen display over the I2C interface (A4 and A5 pins from Arduino): one board with C, LDR, IOs interconnected with a 1mm ZIF connector, or other type, to a second board with supplies and LCD (the encoder is superfluous).
The candidate for this display would be from ELECTRONIC ASSEMBLY. Ive used successfully this type of LCD with touchscreen in military application, but sorry, Im not programmer!
They provide also OLED displays but in this case only over SPI.
ELECTRONIC ASSEMBLY - root LCD Module
Ok, you have to do some firmware modification to implement the LCD.
I know that a lot of people will then positivelly interested in a GB...
Jean-Paul
Hello Jean-Paul,
The i2C 2004 LCD display is really easy to get and cheap - there are hundreds for sale on eBay or in Arduino-related online shops (LCD Display Blue 2004 (20x4) IIC, I2C, TWI )
But of course, any i2C display can be used, if you adapt the software.
You have a cool project going on, keep us updated!
Old 27th September 2015, 07:50 PM   #25
Vincent77's Avatar
Originally Posted by wineds View Post
Could you possibly post photos of the input and power supply pcbs?
Hello,
I don't have photos of these pcbs because the ones I have are an earlier version - the ones published here have been modified/improved.
You can open the PCB file with Eagle to see exactly what it looks like and where each part should go!
Old 28th September 2015, 01:24 AM   #26
Originally Posted by Vincent77 View Post
Hello,
Thanks Vincent! I downloaded Eagle.
Old 28th September 2015, 09:23 AM   #27
Vincent77's Avatar
There is an even better way to see the PCBs: you go to 3D Gerber Viewer | Mayhew Labs and you drag and drop the GERBER files in the viewer there (extract them from the .ZIP first). Then you can see a 3D rendering of the board!
Old 28th September 2015, 09:49 AM   #28
Thanks Vincent. Looking over your design in more detail today this is a very generous contribution indeed to the DIY community! Excellent work!
Old 28th September 2015, 03:13 PM   #29
... work in progress...
eDIP128B-6LWTP (with touchscreen); main power EMC filter and main power ON/OFF.
Fourth board in braining: RTC, elapsed time counter (super caps with charger), temperature sensor.
Missing something? I think about a current sensor? Anyone a schematics or tested circuit?
Old 28th September 2015, 08:52 PM   #30
... I forgot... 6 switched main power 115, 120, 230, 240VAC, with or without NTC...
Thats all for today...
Arduino based LDR volume and source selection controllerHide this!Advertise here!
Passive Preamp: Arduino based, remote control, Relay R2R, input selection maxw Analog Line Level 102 17th October 2017 08:05 AM
Another Modified PGA2311 kit with Arduino for volume control and input selection cjkpkg Analog Line Level 28 15th December 2015 09:21 AM
Source select and passive volume for microcontroller-based preamp? vputz Analog Line Level 3 21st July 2012 10:51 AM
LDR Based Input Selection udailey Analog Line Level 25 5th October 2011 10:03 PM
WTB: LDR-based volume control / pre jdubs Swap Meet 7 2nd December 2010 01:50 AM
