Remote-controlled tube preamp - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 8th August 2015, 06:26 PM   #1
Default Remote-controlled tube preamp
My main setup currently consists of a recently serviced Hafler DH500 and a pair of modded Magnepan MG12--both Craigslist scores--with a Marantz SR7500 as a preamp. Long story short, I think one thing that would take this system from great to incredible is the addition of tube sound in the form of a preamp--not necessarily the warm, gooey sort of tube sound but rather the more linear, lively tube sound with enhanced soundstage/dynamics/extension.
I'd like to keep this project at below $500 total. I'm also not terribly proficient at DIY yet, I've only ever built a Bottlehead Crack and am halfway through buliding an AMB sigma25 PSU (just need to add things to the case), so something in kit form is strongly preferred. I would also like to keep this project below $500, if possible.
So what's the big deal? I've got the Bottlehead Smash and the Transcendent Sound Grounded Grid kits to choose from! Why involve diyaudio readers?
I require remote control. Seriously, I have a rather large living room and I am lazy as hell.
I don't suppose there are any less-than-$500 tube preamp kits with remote control in the world, so I see this as my two options:
1. Build an AMB LCDuino/delta1/delta2 and splice in a tube line amplifier in place of their solid state line amp. I think building all three AMB kits would come out to around $200, which would leave plenty of room for a good preamp.
The issue here: I see plenty of tube line amp kits and PCBs on eBay--even Grounded Grid knock offs from Hong Kong, admittedly tempting given my graduate student salary--but it's difficult to assess their ultimate quality. Are there any highly regarded tube line amp kits out there that would be compatible with the AMB gear? I hear the Aikido is pretty good.
2. Build a Bottlehead Smash and implement some kind of high-quality remote control system for less than $100. The key word here is high-quality... which is something that I, as a newbie to this sort of thing, have a hard time assessing. Any recommendations regarding a good IR-controlled stepped attenuator system OR just an IR-controlled motor that would adjust one of the Smash's pots.
For reference, the input impedance of the Hafler DH500 is 43kohm.
Old 9th August 2015, 04:03 PM   #2
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
I use often these type of volume controls.
MV04 Motorized Remote Volume Control with Input Selector Kit | eBay
And ad a tubebuffer of your choice, i like the 6n16 or 6n6 in srpp/cathode follower setup.
Ronny
Old 9th August 2015, 09:19 PM   #3
gofar99 is offline gofar99  United States
I have used the V02 version as well. All digital with relay switching volume. (no analog pots). I had problems with some of the older V04 units as they were cranky from time to time and when interfaced with high gain circuits introduced noise through the grounding system they used. I stopped using them about three years ago so they may have changed since then. YMMV
Good Listening
Bruce
Old 10th August 2015, 02:28 PM   #4
Koifarm's Avatar
Hello Bruce,
i used several of these kits with no problems. Because of the small housing i used, i always desolder the motorpot and solder the cables straight on the potmeter. Maybe that is why i do not had noise problems.
Ronny
Old 10th August 2015, 02:49 PM   #5
Thanks for the info...I'll give it a try.
Good Listening
Bruce
Old 10th August 2015, 03:06 PM   #6
Koifarm's Avatar
Some inspiration.
http://www.ebay.nl/itm/Assembled-Rem...item33a189a7ba
Old 10th August 2015, 09:27 PM   #7
I'm build speakers but I'm new to everything else. I like what I see so far but I'd want to make sure I didn't sacrifice SQ too much. I want to build a preamp too. Only tube pre that I've used is the Audio Research LS16? I would be amazing to be able to build something that sounded as good as that. Now if volume control can be remote controlled, why not a remote input selector? Or is that does that introduce too much compromise? I'm also into making everything look great. With all the amp housings with heat sinks on ebay, I think that's now more possible than ever.
Old 11th August 2015, 07:26 AM   #8
Koifarm's Avatar
The kit above has also 4 channel remote input selector and remote on/off.
Old 12th August 2015, 01:44 PM   #9
Eric is offline Eric  United States
Eric's Avatar
Koifarm: That is the same remote unit that I am using in my BA-3 preamp. My approach is a bit of a Frankenstein's Monster implementation, but the remote unit works well for input switching and volume control. I have a different implementation where the pot is used to control voltage to an LDR volume control and the relays are used to drive another set of relays on a hacked up DCB1 board, thus the MV-04 is completely out of the signal path in my pre. It increases the implementation overhead, but keeps the signal path short and sweet.
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Old 12th August 2015, 06:15 PM   #10
Koifarm's Avatar
Hi Eric, i do not see why replace the pot for other electronics. we have done listening test with the volume contol and with just 4 resistors and a wire. Nobody heared any difference.
Remote controlled PGA PREAMP for PW120 module..any advice ? Thanks.. dyolFkniP Solid State 14 18th January 2011 04:51 AM
Remote controlled Preamp for PW120 module dyolFkniP Solid State 1 8th January 2011 09:03 PM
Remote Controlled Tube Amp SHiFTY Tubes / Valves 4 16th February 2003 10:58 PM
remote controlled preamp karellen Solid State 4 5th July 2002 06:50 PM
Copyright 1999-2017 diyAudio
