Failure or not?
Failure or not?
Old 2nd July 2015, 02:34 PM   #1
Geoffroy is offline Geoffroy  United Kingdom
Default Failure or not?
Good afternoon to all,
I didn't know where to start this thread, maybe it shouldn't be in DIYAUDIO in which case I'll remove it if asked.
I used to run a cd player directly to my P2100 yamaha amp with a pair of B&W dm2a. The upgrade bug struck me and I bought a Yamaha PC2002M for cheap. I sent it for a good oil change and it came back cleaned up with new light bulds (LEDs tough) but sounding WAY too loud (I couldn't go more than 1 graduation up on the attenuators). Thinking it might be normal (it is a much more powerful amp than the previous one) I went on and found a good deal on a Crown PSl-2 (no MOT or oil change on that one yet), the spec convinced me.
This setup: marantz CD 5001 + PSL-2 + PC2002M + DM2A is now more reasonable for ear protection purposes but I am not convinced sound wise at all. It is just too bassy (clean bass though) and I need to raise the volume a lot to get a good soundstage. It is worth writing that I haven't changed the room at all (and I know it's not the best setup for such a place) so the comparison in terms of acoustics is like for like. In the future I intend to use the crown as a volume control and switch (which it should do really well as, according to the spec, it should be transparent with tones defeated) but I not yet convinced.
What do you think could be the issue? If I need to send my PC2002M back I am not sure I trust the guys who did the works (these guys are real pros but I think I'll go to a yamaha pro audio approved tech).
thank you in advance for your reply/ies.
Best Regards
Geoffroy
P-2100, P-2002M, Crown PSL-2, B&W DM2a
Old 6th August 2015, 10:26 AM   #2
thaumaturge is offline thaumaturge  United States
thaumaturge's Avatar
Is it possible that you plugged into an amplified -headphone out- vs a "line" output on the CD when you reconnected it? That would explain your sudden volume surge.
Doc
Noli timere problematum affigit
Old 6th August 2015, 11:55 AM   #3
have you got "Power Amplifiers" or do they have some other inputs that are not flat, or have extra gain?
regards Andrew T.
Old 6th August 2015, 12:11 PM   #4
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Failure or not?
they are both 0.775V in for full power, but the new amp is 3 times the power so will have 18dB more gain. Looking at the specs they both have input attenuators, but these are pro amps so this is for setup rather than operation. The marantz doesn't have a variable output so a pre-amp would be needed (unity gain buffer type).
Old 6th August 2015, 01:14 PM   #5
DF96 is offline DF96  England
3 times the power is 4.7dB, not 18dB. 3 times the voltage would be 9.4dB. 18dB is 8 times the voltage or 64 times the power.
Note that in audio "real pros" may be exceedingly incompetent, or hugely competent, and you can't tell from customer reviews or magazines which is which.
Old 6th August 2015, 01:17 PM   #6
billshurv's Avatar
Failure or not?
yes sorry, was trying to think, type and deal with a little squeaker all at once on 3 hours sleep. Multi-tasking is for the wife
Old 6th August 2015, 02:13 PM   #7
You're excused. A problem I have never had to deal with.
regards Andrew T.
Old 6th August 2015, 02:18 PM   #8
billshurv's Avatar
Failure or not?
The first 18 years are the worst!
Failure or not?Hide this!Advertise here!
TO 3 failure on vibration gmphadte Solid State 24 6th February 2014 08:57 AM
EL34 Failure PeteM Tubes / Valves 14 21st March 2007 01:25 AM
Google Failure? Bas Horneman Everything Else 6 21st October 2005 03:55 PM
Tube Failure jwatts Tubes / Valves 11 12th February 2005 07:54 AM
7591EH failure Frank Berry Tubes / Valves 10 30th August 2004 06:18 AM
