diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analog Line Level (http://www.diyaudio.com/forums/analog-line-level/)
-   -   MOX - active crossover (http://www.diyaudio.com/forums/analog-line-level/27651-mox-active-crossover.html)
moamps 5th February 2004 10:44 PM
2 Attachment(s)
Hi, all
here is my prototipe of an active crossover - SK filter with 6-12-18-24 dB slope, Q from 0.5 to 1, and standard 1/3 octave central frequency. I'm using this crossover now in an active PA speaker project of mine. Schematics and pcb's have been tested and are working fine. PCB's are one layer style with a couple of jumpers, opamp is placed on a small "daughter" board and can be IC or discrete. If you find it useful, feel free...
moamps 5th February 2004 10:45 PM
2 Attachment(s)
LPF filter schematic
moamps 5th February 2004 10:47 PM
2 Attachment(s)
HPF filter schematic
moamps 5th February 2004 10:48 PM
2 Attachment(s)
discrete opamp
moamps 5th February 2004 10:50 PM
2 Attachment(s)
complete xover
moamps 5th February 2004 10:53 PM
2 Attachment(s)
measurements...24dB/oct LPF, middle decade
moamps 5th February 2004 10:55 PM
2 Attachment(s)
measurements...1kHz lpf 24dB/octave, diferent Q
moamps 5th February 2004 10:59 PM
2 Attachment(s)
parts list
Peter Daniel 5th February 2004 11:12 PM
I'd say, you'd finished what Grey started. Congratulations on a job well done. Will definitely try this one.;)
Peter Daniel 6th February 2004 04:26 AM
Looking at the schematic, I see you have 10K volume pots for ea. section of the crossover.
It seems like a perfect setup to use APOX SHM controller here, as one could set permanently offset levels and then adjust all 4 channels simultaniously. By increasing the gain of op amp, one might combine preamp function with high quality active crossover.
From the schematics I've seen so far, this one seems to be the most appealing (especially when it's based on XVR1;))
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
