MOX - active crossover
Old 29th February 2004, 06:24 PM   #81
promitheus is offline promitheus  Europe
promitheus's Avatar
I also have found that good discrete opamps sound a lot better than opamps like opa627 or opa637. I have tested that in a simple preamp.
Has anybody built any of the above circuits or are there any pcbs made for them?
Old 29th February 2004, 11:11 PM   #82
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default Just a note about the filter and changing Q
You problably all know this, but be sure to have a gain adjustment on the output of the filter section.
When you change the Q of a sallen and key filter by means of the qain, you also change the pass band gain.
So of gain is = 2 you must have a gain of 0.5 on the output to ensure that the following stages are not clipping.
\Jens
Old 1st March 2004, 12:36 AM   #83
grataku is offline grataku  United States
Great work moamps, thanks for posting it here.
The last time I tried an active X-over I wasn't too impressed but being a discrete design with everything variable it maybe time to give it another try
I am definitely interested in getting a couple of boards (whatever many boards one needs to get a stereo two way balanced filter).
I would do the board but I don't have any time to spare right now.
Maybe we should all wait for the chinese to get it done.
Old 1st March 2004, 06:31 AM   #84
Default I'm not chinese but....
I'll do it. I'm starting on the schmatics for one block today. when done ill post the result.
Please comment if the schematics posted already are like you want them, or if they schould be changed in any way.
Also, ill do the layout using dual opamps, so if you want a descrete opamp make a dual one that can fit in a 8 pin DIL socket.
\Jens
Old 1st March 2004, 06:46 AM   #85
Blitz is offline Blitz  Germany
Great, Jens. Many thanks upfront.
Old 1st March 2004, 07:02 AM   #86
Why don't you want to go for the discrete opapms ? Can't you have a more robust connection option on the board for the discrete ones ? DIP8 only is a bit fragile when looking at the Boards of Moamps.
Old 1st March 2004, 07:22 AM   #87
Default Opamps
I feel that a Q of 1 is a bit too littel, so how about making the option og Q go from 0.5 to 2.0 in steps of 0.1?
The reason is that this gives the option of using the HP section as a low frew EQ for a sub or small speaker system.
I do not think that descrete opamps bettet are than some of the IC's you can get, if they were, opamp designers would have made them into a commeciel product many years ago.
\Jens
Old 1st March 2004, 07:53 AM   #88
Having variable Q is a good idea. I would be especially interestd to have an eq for the super-trebles above 15khz.
Understand your theory about discrete opamps, but have you actual listening experiences you can share ? Anyhow, it would be great to have the option to use discrete opamps with a stabile connection.
Old 1st March 2004, 09:16 AM   #89
promitheus's Avatar
I am very interested in making an active crossover but only if it is with dicrete opamps. One thing that is always missing is equalisation at different frequencies. Specially woofers have dips and peaks that have to be corrected. How do you do that? For instance my Peerless woofers have a peak +3 dB at 1,8 KHz from 800 Hz to 3KHz. I correct that passive with an LRC series network. It would be helpfull to also do this active.
Old 1st March 2004, 09:22 AM   #90
Default Eq
Check this dok for info on EQ and active cross overs
http://www.delta-audio.com/Active%20filter%20one.htm
\Jens
MOX - active crossoverHide this!Advertise here!
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
PA vs DIY active crossover paulspencer Multi-Way 46 27th November 2004 01:25 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
