MOX - active crossover
Old 2nd April 2004, 09:47 AM   #191
moamps is offline moamps  Croatia
Originally posted by promitheus
About the coils, yeah I know those cores but is it a matter of turns only or do you need an LCR meter to be sure?
you need LCR meter or scope and some audio generator or some PC-based audio analyzator.
Old 7th April 2004, 11:52 AM   #192
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default Updated schematics and second layout
Hello all,
I updated the schematics and PCB version for the group.
They can be found as PDF's here:
http://www.delta-audio.com/Active%20filter%20two.htm
Please comment so we can get this thing running
\Jens
Old 7th April 2004, 05:48 PM   #193
tiroth is offline tiroth  United States
Nice work Jens. I've traced through the schematics and they look good. I should have time to trace through the PCB tonight.
Old 7th April 2004, 06:12 PM   #194
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Good job, Jens!
I've seen that your layout uses dual in line sockets (single opamp?) instead of moamps' SIL for the discrete opamp.
This gives the opportunity to use standard opamps, but is left unclear if those who still want to use discrete opamps will have to make their own adapters or if you or tiroth are going to make a suitable layout in order to produce such pcbs also while we are at it.
In the wiki there was also a mention to regulators (Jung type): are you planning to make boards for them also or should we go with the group buys currently in progress?
Cheers
Andrea
Old 7th April 2004, 08:24 PM   #195
Default Stuff
The module is made with standard dual op amps and no copy of the Jung regulator is plannede. As for descrete opamps I have no plans for that on this board.
However I'm designing a +- 15V supply to be used with my other filter project.
\Jens
Old 8th April 2004, 06:49 AM   #196
promitheus is offline promitheus  Europe
promitheus's Avatar
I am not sure but I think there is a problem with the PCB pdfs. I see the bottom and above layer the same.
I think you have the same thing there.
Old 8th April 2004, 12:14 PM   #197
Default PDFs
Hello,
I can't find any porblems with the PDFs - do you have different names for the two layers (Top and Bottom)?
If the problem persists I can mail you the files - just mail me and I'll answer ASAP
\Jens
Old 8th April 2004, 01:07 PM   #198
Andrea,
I wouldn't mind doing a layout for the discrete opamps, but I wonder how much interest there would be in a buy. It is expensive to make lots of small boards.
promitheus ,
Are you sure? There is ground fill on both sides...
Old 8th April 2004, 01:13 PM   #199
Andypairo's Avatar
If you see the Wiki there are >150 of these boards "requested" if everyone confirms the interest, but have no clue if they will.
My idea was that it can be nice to have the discrete opamps with PCBs of the same quality of the main PCB, but only if it can be done at a "right" price.
Cheers
Andrea
Old 8th April 2004, 01:33 PM   #200
Default Moving on.....
Hello,
All I'd like to know is weather or not to start cleaning up the schematics and the PCB.
\Jens
MOX - active crossoverHide this!Advertise here!
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
PA vs DIY active crossover paulspencer Multi-Way 46 27th November 2004 01:25 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
