MOX - active crossover
Old 6th February 2004, 08:04 AM   #11
moamps is offline moamps  Croatia
Originally posted by Peter Daniel
It seems like a perfect setup to use APOX SHM controller here, as one could set permanently offset levels and then adjust all 4 channels simultaniously. By increasing the gain of op amp, one might combine preamp function with high quality active crossover.
this is good idea. Also, one another solution is using 4 channel resistor attenuator with proper screening between sections if remote control isn't needed. Tracking between channel and filters in this case must be very good.
Old 6th February 2004, 08:26 AM   #12
vytas is offline vytas  Lithuania
Default Nice work
It seems simple and quit good solution!
Old 6th February 2004, 02:37 PM   #13
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Excellent job Moamps,
Looking at the schematic, I see you have 10K volume pots for ea. section of the crossover.
From the schematics I've seen so far, this one seems to be the most appealing (especially when it's based on XVR1)
If you wanted to get real fancy, you could let the APOX processor do the frequency and slope switching with a set of relays driven from the processor. Than have the frequency and slope displayed on the screen.
Rodd Yamashita
Old 6th February 2004, 03:25 PM   #14
tiroth is offline tiroth  United States
Very nice work. A project like this was definitely needed. Even for those not biamping this is a great (and inexpensive) tool for designing crossovers.
Old 6th February 2004, 03:54 PM   #15
chris ma is offline chris ma  Canada
chris ma's Avatar
Default group buy
Hello moamps,
Have you consider making and selling the PCBs?
Chris
Old 6th February 2004, 04:34 PM   #16
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Default Re: group buy
Originally posted by chris ma
Hello moamps,
Chris
Since my spare time is very limitated I can't but agree with Chris, also providing the main components (I.E. the double fet and the resistor/capacitors array) would be very appreciated.
Cheers
Andrea
Old 6th February 2004, 05:23 PM   #17
roddyama's Avatar
Hello moamps,
Chris
I would be in for that as well, multiples.
Rodd Yamashita
Old 6th February 2004, 05:40 PM   #18
jam is offline jam  United States
jam's Avatar
Good job Moamps!
..........Rodd will buy anything.
Jam
Old 6th February 2004, 06:31 PM   #19
roddyama's Avatar
What are you selling Jam, anything?
Rodd Yamashita
Old 6th February 2004, 07:12 PM   #20
jam's Avatar
Not today Rodd...............but I am reading this new book......
MOX - active crossoverHide this!Advertise here!
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
PA vs DIY active crossover paulspencer Multi-Way 46 27th November 2004 01:25 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
