TDA 1524 tone control - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th June 2015, 07:22 AM   #1
Default TDA 1524 tone control
Hi Guys,
I tried building TDA 1524 tone control, twice but failed. quality not good, I changed ICs, even capacitors and resistors, checked PCB tracks, everything.
can someone throw some light on what might be wrong? does anyone have a successful PCB for this?
Old 29th June 2015, 08:48 AM   #2
DF96 is offline DF96  England
Two likely problems:
1. the circuit was wrong
2. the circuit is fine, but you didn't build the circuit but instead you built a different circuit - then in checking this circuit you carefully applied the same misunderstanding which led you to build it (e.g. chip pins).
My crystal ball is away for repair, so that is about as far as I can go with the information you have given us so far.
Tone control argonrepublic Solid State 11 13th November 2011 01:32 AM
TDA 1524 + TDA 1574 - Portable active speaker ricardoporto09 Chip Amps 1 27th October 2011 11:38 PM
tda 2050 volume control asbn369 Chip Amps 1 24th July 2010 06:12 PM
Tone control argonrepublic Solid State 0 28th February 2010 12:12 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
