TKD 2P-2511S - 21 steps replacement AN Kit One - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th June 2015, 12:46 AM   #1
beto1 is offline beto1  Chile
beto1's Avatar
Default TKD 2P-2511S - 21 steps replacement AN Kit One
Hello All,
I have to replace my TKD 2CP2511 volume pot on my AN-KIT 1, which is 10 years old and is beginning to fail. I was thinking of replacing it with the 2P-2511S TKD 21 steps, stepped attenuator that has the same size so it is very simple to replace.This series attenuator has the first steps with 2dB increments (Attenuation (BTS-50dB) 0, 2, 4, ...(2dB step)... , 30, 32, 34, 37, 42, 50), so i'm a little concern because I will build a pair of 97 dB sensitivity speakers and I don't know if will get too louder at the first or second steps.
My second choice is an Acoustic Dimension 41 steps series attenuator, but it wont fit without a big modification as my amp has the volume pot in the center with a reduced internal space that barely fit the TKD.
Any comment will be wellcome.
Last edited by beto1; 18th June 2015 at 01:47 PM. Reason: to complete statement of the topic
Old 18th June 2015, 07:46 AM   #2
What is the output voltage of your Source?
What is the maximum signal at the speaker?
What is the gain between the Source and the Speaker?
What attenuation do you need to prevent clipping?
regards Andrew T.
Old 18th June 2015, 08:11 AM   #3
nanchangbob's Avatar
If the 2CP-2511 has been working fine for you why don't you just replace it with another 2cp-2511? Parts Connexion has them in stock and they have a 20% off sale until the end of June.
A great day to listen to music.
Old 18th June 2015, 10:22 AM   #4
EUVL is offline EUVL  Europe
You can still use the 2P-2511S and tailor fit to your attenuation requirements by replacing the resistors inside.
Then you can get whatever total impedance, taper and max. attenuation you might want.
Another lower cost option is to buy a "fake" RH2702 and replace all the resistors with Susumu thin film (0.5% or better).
This also gives you the same flexibility as mentioned.
Both options above are so-called series stepped attenuators.
Here is a solution for a ladder type that will fit into the same small volume.
BUT still work in progress.
The DAO SE all-FET Class-A ZGF Headphone Amplifier
Patrick
xen-audio.com
Old 18th June 2015, 02:38 PM   #5
beto1's Avatar
Sorry Andrew, I can't answer those questions.
Old 18th June 2015, 02:47 PM   #6
beto1's Avatar
Hello nanchangbob, I just want to try a new one after 10 years. I recall that was a huge improvement over the stock cheap pot. As far as I know this resistor based attenuator have a better channel match and more transparent sound. The cost difference between the 2CP and 2P is not that big and if this sound a little better, will be wellcome.
Thanks for answer.
Old 18th June 2015, 03:08 PM   #7
beto1's Avatar
Patrick
Thanks Patrick !
A ladder attenuator in an small size is just what all people are wanting.
Old 18th June 2015, 03:10 PM   #8
If you want to predict this before you buy, the you need the answers.
we can't tell you.
regards Andrew T.
Old 21st June 2015, 05:35 PM   #9
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
This series attenuator has the first steps with 2dB increments (Attenuation (BTS-50dB) 0, 2, 4, ...(2dB step)... , 30, 32, 34, 37, 42, 50), so i'm a little concern...
OK, so what is the attenuation of your current volume control in its first few steps? What is the attenuation of your current volume control in the rotation range where you use it the most?
Alcohol, taken in sufficient quantities, may produce all the effects of drunkenness. - Oscar Wilde
Old 21st June 2015, 08:39 PM   #10
beto1's Avatar
Hello Nez Bleu,
my current volume pot (CP2511) is very similar to the stepped attenuator (C2511), but the main difference is that the C has from 100% attenuation to the first step has an increment of 8dB, then has 7dB to the second step, then 3 dB to the third step and the CP get the same, but in a continuous path. I used to heard between the 1/2 position to 1/4 on my room with my current 91 dB sensitivity speakers, but I will build a speaker pair with 97 dB soon, so maybe this few first steps from 100% attenuation to 1/4 of the turn would be hard to set fine tuning control.
I don't have all the data to calculate the system gain, but I am trying to get now.
Best regards
Ultra Analog AES-21 Upgrade / Replacement Project nacc18 Digital Line Level 13 21st January 2015 06:03 AM
Dact Type 21 vs. TKD 2500 series greg7 Parts 0 11th December 2014 01:41 AM
Replacement tweeters for DynAudio D-21/2 searchin4thesound Multi-Way 7 19th June 2013 03:00 AM
Made two steps forward and three steps back pjpoes Solid State 5 3rd June 2007 02:22 PM
Alps pots vs. TKD pots? TKD worth the extra$$? G Tubes / Valves 11 17th August 2004 04:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
