How to Null the output of a diff amp please? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 8th June 2015, 07:46 PM   #1
Default How to Null the output of a diff amp please?
Hello,
Hopefully an easy question for someone
I wish to utilize a standard configuration instrumentation differential amplifier thus:
I would like to know how such an amplifier can be null'd?
i.e. if inputs are shorted together (by pressing SW2 'Test') then how can the circuit be modified to be able to ensure the output sits at 0V?
I was thinking maybe instead of connecting R24 to GND, connect it instead to an adjustable reference which nominally sits at 0V.
I have also seen this which intrigues me:
I like the way the second stage amplification is implemented, maybe replacing the two 1M resistors with a trimmer and reference connected to GND.
Anyway ideas, corrections, suggestions greatly appreciated!
Andy
Old 9th June 2015, 02:07 AM   #2
To give you the idea, Google for:
Application Note 31 Op Amp Circuit Collection
Look on pages 6 and 7.
An absolute null is probably impossible because of component and temperature variations. But single digits is achievable.
Or, of course, use an output capacitor.
Old 9th June 2015, 02:23 AM   #3
DUG is offline DUG  Canada
Introduce a low impedance/low resistance controlled voltage where R24 connects to ground.
See jpg...courtesy of TI from one of their data sheets.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 9th June 2015, 07:55 AM   #4
there are a couple of THAT ap notes that mention this.
I think Whitlock also does a servo for the diff amp.
Jung maybe?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th June 2015, 08:00 AM   #5
Cheers chaps,
@AndrewT, have you any useful links to what you mention please?
Also note that I am measuring things in the DC domain... The input to the diff amp is a stable measurement that if anything will only change with altering temperature of the devices being measured (compared).
Thanks again,
Andy
Old 9th June 2015, 09:05 AM   #6
Chopper type.
regards Andrew T.
Old 9th June 2015, 07:48 PM   #7
A chopper... mmmm, maybe?
However I only want to achieve a differential V gain of 1000 preferably, thus converting mV difference (up to 10mV abs max) at the two inputs to a corresponding V (with reference to my elusive GND) at the output. Using a chopper maybe a sledgehammer to crack a nut perhaps? I am no expert when it comes to opamps.
Thanks again,
Andy
Old 10th June 2015, 02:12 AM   #8
Some low offset opamps:
Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps | Integrated Circuits (ICs) | DigiKey
Some almost two orders of magnitude better than LT1058.
OP-amp null? johngalt47 Parts 5 3rd May 2015 12:03 PM
Carver + null difference test + how can i copy a amp umutmt Analog Line Level 2 4th September 2007 03:03 AM
Output stage/preamp with gain: X-Bosoz with diff.-pair? Onvinyl Pass Labs 1 19th July 2004 08:29 AM
Diff amp driver -> SE output Saurav Tubes / Valves 13 8th January 2004 04:42 AM
help with diff. output Raj1 Digital Source 4 9th September 2003 05:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
