'slow down' ad797 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 1st May 2015, 05:03 PM   #1
donovas is offline donovas  South Korea
Default 'slow down' ad797
hello. i build composite headphone amp. ad797 inner loop. but it oscillate. maybe slew rate too much? how do i slow down slew rate? this inverting input- so cap from output to inverting input? 100pf for start? thank you.
Old 1st May 2015, 05:05 PM   #2
rayma is offline rayma  United States
First post a photo of your pcb and the schematic.
Old 1st May 2015, 06:25 PM   #3
i p2p this. works with 811. but i socket them both so i can change different opamps. i want slow down 797 so that it work with other opamp.
Old 1st May 2015, 06:26 PM   #4
also invert input version instead. it also work. only with 811
change 22pf higher?
Old 1st May 2015, 06:47 PM   #5
also invert input version instead. it also work. only with 811 change 22pf higher?
First I'd try removing the 22pF cap, and instead adding a series RC network directly across the 797 input terminals.
Start with a 100 Ohm resistor in series with 2.2nF. If this helps reduce the oscillation, we can further adjust the values.
BTW, make sure that the input is always terminated, either with the signal generator, or a short to ground.
Old 1st May 2015, 07:22 PM   #6
juma is offline juma  Germany
juma's Avatar
change 22pf higher?
Change its place - put it between pin 6 and pin2 of AD797. See what you get and adjust its value if needed.
Old 1st May 2015, 07:57 PM   #7
across +/-? wow, value very high. i will try, thank you
i will try 22pf in someplace else, too.
Old 1st May 2015, 07:59 PM   #8
Try without the 22pF first. The RC network adjusts the HF noise gain of the amplifier.
Old 2nd May 2015, 12:20 AM   #9
Also - sockets are a big problem with opamps like these!
Those decoupling caps need the shortest, most-direct return to power 0v possible; your 0.1uF caps need to have zero lead length. Sockets add inductance, and ruin things; without really 'tight', well-considered layout I am not surprised you have oscillation problems.
My suggestion - take the AD797 out and try something with considerably less GBW product: NE5534, OPA604 or similar - and get the circuit working as nice as you like. Then develop it for a faster opamp, and refine the physical layout using the lessons learned.
Old 2nd May 2015, 12:27 AM   #10
Yes, ideally an all SMT layout with a solid ground plane would be best in this case.
ad797 vs ? for i/v? PreSapian Digital Line Level 6 20th December 2013 02:10 AM
ad797 questions nonsqtr Analog Line Level 18 23rd July 2013 05:53 PM
Tips for AD797 ?? redrabbit Everything Else 11 2nd October 2008 04:55 PM
AD797 guts aparatusonitus Solid State 3 21st March 2008 05:02 PM
Ad797 audioPT Parts 12 31st October 2003 09:07 PM
Copyright 1999-2017 diyAudio
