DC offset from the line level stage. - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th April 2015, 04:19 AM   #1
Send a message via MSN to chchyong89
Default DC offset from the line level stage.
Hi friends
I have built a balanced line buffer recently but I am having a 28mV offset (reference to GND) from both of the outputs surprisingly. Attached is the schematics, and the offset labeled.
I tried adjusting the gain, series a caps + shunt a 10kohm into Gnd to the LME49610 non-inverting inputs, ground the lme49990 non-inverting pin, but still resulting the same offset.
I am guessing adding a trimmer at the OCM pin can eliminate it but it's a bit pointless no? Any clue on where is the offset comes from?
PS. The Gnd from every node in PCB remained as 0mV, so there is no "bad/leakage gnd" in PCB drawing.
www.stoneracoustics.com
Old 28th April 2015, 04:44 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Seeing as a quick review of the offset voltages and input bias currents to be expected doesn't account for your measurements, it seems likely to me that you've got some low-level oscillation going on. The LME49610 is introducing some HF phase shift so perhaps your OPA1632 isn't so happy operating with its phase margin considerably reduced. There's no plot of the OL gain for that part in the DS I have so its just speculation.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 28th April 2015, 08:46 AM   #3
does the feedback from the buffer out return to it's own input at the opamp?
Or should the feedback cross over to the other side?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th April 2015, 09:14 AM   #4
Hi Andrew,
No additional feedback line back to the lme49610 itself, I did tried to cross the feedback of opa1632 but that make the circuit stop to work. The circuit is working and singing fine but the 28mV offset is annoying.
I did tried swap with a LME49724, resulting a 26mV output offset reference to ground. When i float up the ocm pin the output offset reduced to 13mV reference to gnd. It seems like a trimmer can't be avoided in such case.
Old 28th April 2015, 11:05 AM   #5
The top input to the opamp is +IN.
The top output from the opamp is +OUT.
The Buffer is non inverting.
You have the feedback from +OUT back to +IN. That is positive feedback.
I think the top output needs to go to the bottom input.
And the bottom output needs to go to the top input.
The 1632 datasheet should confirm the polarity of the 4 IN/OUT
regards Andrew T.
Old 28th April 2015, 11:41 AM   #6
Yes, i wont make a small mistake like that.
a crossed/positive/wrong feedback wont even let this amplifier work anyway.
Old 8th May 2015, 04:38 AM   #7
Was just tried to ran a non-composite opa1632, ground the Vocm, series resistor input to ground for both channel, tried different batch of opa1632, the offset is still there.
Old 8th May 2015, 06:07 AM   #8
There is nothing wrong in whatever is happening. Unless you offset null one of the output, nothing will change.
Gajanan Phadte
High Dc offset voltage on the input line nkirk Analog Line Level 7 5th November 2013 11:36 AM
DC offset on power line percy Solid State 9 23rd February 2012 10:39 AM
AD1865 - passive i/v stage dc offset lordearl Digital Source 5 12th May 2011 11:43 AM
Audio line DC offset foryourdemons Analog Line Level 3 27th March 2010 08:43 AM
DC offset on household ac line ? percy Chip Amps 9 24th January 2006 09:30 AM
Copyright 1999-2017 diyAudio
