Noisy trough - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 20th April 2015, 02:40 AM   #1
Default Noisy trough
I have an 8ohm speaker driven by an LM386, function generator, and lab power supply. Everything is carefully bypassed. For most frequencies when I apply a sin wav or sawtooth wav the input is clean, but the output has the lower part of the trough filled in with noise (on the oscilloscope). I can't figure out what this could be. Speaker/mechanical resonance that needs damping? Any suggestions for solving this? Thanks!
Old 20th April 2015, 03:16 AM   #2
DUG is offline DUG  Canada
Do you have the 10R-0.05uF network on the output, it is critical for stability.
I used this amp once for a metal detector AF amp, had stability issues without it.
See page 5 of schematic...all amps on this page have it on.
http://www.ti.com/lit/ds/symlink/lm386.pdf
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 20th April 2015, 03:20 AM   #3
I don't. I can't believe I missed that. I will try it Tuesday when my lab reopens and I have an oscilloscope on hand. Thanks.
Out of interest, would you know why it is required, given that the power supply and input are already bypassed?
Old 20th April 2015, 08:56 AM   #4
DF96 is offline DF96  England
The Zobel network at the output keeps the feedback loop stable at ultrasonic/RF frequencies. Most solid-state amplifiers need this. Nothing at all to do with bypassing - that deals with other sources of instability.
Old 21st April 2015, 06:10 PM   #5
Thanks guys. That solved the noisy trough problem. Clean as a whistle now.
Old 21st April 2015, 10:16 PM   #6
ostripper's Avatar
Move deep into rural area's , use incandescent lamps and have no digital
"toys" (TV , pC's ...).
really .. your power line is "dirty" from all the cheap walmart 21'st century
garbage.
added a ground to a old house mains box. the only place my scope could
NOT see noise was at the ground rod itself and at short run circuits used
for the outside outlets.
Filters , using a separate house circuit (one close to the mains box).
For the actual AC , even the utilities line will pick up a close RF source.
remember the "whole house antenna" back in 1980 - it works !
OS
Mongrel website , always current and updated :
http://www.fidelityforce.com/ostripper
Old 22nd April 2015, 09:35 AM   #7
The "noise" in the trough was not noise but parasitic oscillation.
Possibility of Tube substitution trough MOSFETs tiefbassuebertr Tubes / Valves 20 31st July 2009 12:14 PM
ET 2 (air bearing) fluid damping trough AVWERK Analogue Source 2 14th August 2008 01:37 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
Max current trough a 3.5mm mono jack. Douchekop Parts 3 25th August 2005 10:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
