mic mixer with echo/delay feature connection
Old 18th April 2015, 02:23 PM   #1
wertz is offline wertz  Philippines
Default mic mixer with echo/delay feature connection
hi. long story short, i had modified and converted the passive tone control my existing sound system into an active one. then feed into volume control and then out for amplifier. my question is how to properly its internal mic mixer properly? the opamp in this section used to be an inverting amplifier wherein the output of passive tone control was feed and the mic is mixed using a 47k resistors for left-right channel. now im thinking the right way to connect the mixer is after volume control on its center leg so mic volume will be separate from main volume. but can i just connect directly using resistors (like the existing 47K) for left-right channel or do i need to build a summing amplifier.
thanks.
mic mixer with echo/delay feature connectionHide this!Advertise here!
microphone echo & delay fx circuit sudhir kumar Analog Line Level 34 21st September 2011 03:19 PM
echo, reverb using bucket brigade delay lines from panasonic Workhorse Solid State 20 6th April 2011 12:37 AM
cassette tape echo / delay thegunshyboy Instruments and Amps 10 23rd November 2006 11:36 PM
PT2399 Echo / Delay Audio chip -_nando-_ Digital Source 1 28th August 2006 02:53 AM
Delay - echo through BL and FL horns jamikl Multi-Way 4 3rd April 2006 06:52 AM
