Layman's question for the pros - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 20th February 2015, 04:13 PM   #1
Default Layman's question for the pros
I have Adcom GFA-565 mono blocks that are rated 300w/8-ohms. They have a 27db gain. How many mv from my amplifiers RCA pre outs do I need to reach their full potentials?
Old 20th February 2015, 04:28 PM   #2
JonSnell Electronic's Avatar
Here you are;
20*log(x) = 27dB X= voltage ratio output/input Therefore X = 31,7
Voltage required for 300W RMS into 8R ( P/R = I2 = approx 6.2A
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th February 2015, 04:32 PM   #3
Is half the calculation missing?
I make it 1.5VRMS for peak output BTW.
Old 20th February 2015, 05:16 PM   #4
1.5V is correct. What does BTW mean?
Old 20th February 2015, 05:27 PM   #5
Yes, please. I need calculations to the mv level. Though Jon's clarification is much appreciated, it's a long time since Mr. Planks maths class (also from England) . I require something at the mv level. I'm looking at the Onkyo NR838 with an RCA line out of 200mv but a Max line out of 480?
Old 20th February 2015, 05:29 PM   #6
DrDyna is offline DrDyna  United States
DrDyna's Avatar
That seems really low for that unit.
Oh, I see, the specs say "rated" and then "maximum" ...it's a little bizarre that the two numbers they give are so far apart..guessing though, I'd say you won't have any problem driving a 565 with it.
Edit: More strange specs on that sheet, evidently the tone controls operate at 20 hz and 20 khz.
Old 20th February 2015, 06:01 PM   #7
.BTW= by the way
Ok,
Rated RCA output and impedance 200mV/470 ohms
Maximum RCA output level and impedance 4.6V/470 ohms
Will I obtain my 300w rms at 8ohms with this amp?
Old 20th February 2015, 09:01 PM   #8
DrDyna's Avatar
I would say "probably", but the way they've worded the specs is very odd to me. 4.5V seems like a reasonable maximum output, but it's odd that they included a "rated output" that's what, like, 25x lower?
So, the answer is, if the maximum unclipped output is 200mV, no.
If the maximum unclipped output is 4.6V, yes.
Old 20th February 2015, 09:20 PM   #9
diyAudio Member RIP
My best guess is input sensistivity for line inputs is 200mV.
And at full gain gives 4.6V. Output = 200mV = nonsense.
rgds, sreten.
Old 20th February 2015, 09:36 PM   #10
cbdb is offline cbdb  Canada
They may be saying that the diference is the head room of the amp, a little strange but makes sense.
Newbie question: Pros/Cons of a Preamp after a Bufalo III ElEsido Twisted Pear 3 29th June 2011 06:40 AM
This is how the pros do it pacificblue Construction Tips 0 12th September 2010 06:37 AM
Cons / Pros Borat Tubes / Valves 34 1st September 2009 12:52 PM
Lobbing What is it in layman's terms? mrteleportal Multi-Way 5 24th November 2004 10:00 AM
Copyright 1999-2017 diyAudio
