DIY Sine Wave Oscillator Trouble - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th February 2015, 11:14 PM   #1
Default DIY Sine Wave Oscillator Trouble
Hello
Sorry if this is in the wrong forum.
I've built an oscillator from these schematics.
Identify diagram: Wideband Wien Oscillator Circuit with Single Gang Pot
At the moment I only get light (from the LED) and sound when the switch is set to go through the 1uf capacitors. With the switch on the three other positions, there is no sound at all except for the normal hiss when you turn up the volume pot.
I've checked and re-checked every component and every bit of soldering. There's continuity where it should be and I've even tried 2 batteries in series just in case I wasn't getting enough voltage.
I can build these things but I'm not great at understanding the circuitry. if someone out there knows the theory behind this circuit, then any help and possible modifications needed in order to make this work would be hugely appreciated.
Thanks for your time
All the best
Old 16th February 2015, 10:33 AM   #2
DF96 is offline DF96  England
You could try contacting the author. Merlin Blencowe is a member of DIYaudio (user name Merlinb).
Old 16th February 2015, 11:09 AM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
Did you place the LED + LDR inside a completely opaque contaiiner?
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 16th February 2015, 01:17 PM   #4
Yeah, no light could get to them
Old 16th February 2015, 06:07 PM   #5
The 1uF cap should cover 15Hz to 150Hz is this what you are getting and have you used the specified LDR
Old 16th February 2015, 06:29 PM   #6
Yeah I used the exact LDR they specified and I am getting approximately that frequency range from the 1uf cap.
Old 16th February 2015, 08:01 PM   #7
I will say sorry up front but you are selecting 2x 1uF caps then 2x 100nF etc when you are turning the rotary switch as the switch numbering on the schematic is unusual , certainly to me .
Old 16th February 2015, 08:06 PM   #8
No need to say sorry, any thoughts are helpful. Yes, I've arranged the switch so that it's the 2x 1uf caps at the same time, then 2x 100nf etc.
Old 16th February 2015, 08:34 PM   #9
benb is online now benb  United States
Looking again, the parts list gives a specific part # for the switch. Googling:
RTAP42S04WFLSS C&K Components | Mouser
And clicking one more time gives the data sheet:
http://www.mouser.com/ds/2/60/RTA_4jun13-33438.pdf
This has many models of different poles and positions in one rotary switch case, which tends to explain the odd and "non-standard" pin numbering for most configurations.
I'd get a meter and check for proper connections at each switch position to double-check that the actual switch connections are what I understand them to be.
Old 16th February 2015, 10:42 PM   #10
I just went with a standard 2 pole 4 way slide switch and wired it so that it went to the two appropriate capacitors for each position. Regardless, I'll have another check that the proper connections are in place.
OP Amp oscillator sine wave too sharp LATUBEGEEK Solid State 14 3rd March 2014 04:43 AM
Linn Lingo vs. Dr. Fuß or Square-Wave vs. Sine Wave Oscillator for Motor Control tiefbassuebertr Analogue Source 62 15th December 2013 11:23 PM
Seek pure sine wave oscillator schematic ... gentlevoice Power Supplies 5 5th September 2012 06:59 PM
Wanted: HP 209A Sine/Square Wave Oscillator scott17 Swap Meet 0 15th March 2012 03:58 AM
HP 202C LF Oscillator (tube sine wave generator) $20 pjanda1 Swap Meet 2 23rd July 2011 03:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
