Buffer output for PCM1794A
Old 14th February 2015, 09:08 AM   #1
snowcatmaiden is offline snowcatmaiden  Hong Kong
Default Buffer output for PCM1794A
Hello, first thread here
I before had LT1028+BUF634 after the I/V converter of PCM1794A.
It worked very well, not in term of quality though
Today I built a discrete diamond buffer to replace the BUF634, like in the picture.
And, at the start it sounded much better. But then the output level was getting gradually smaller,
while the background noise gradually become larger, after playing for a minute.
By the wonder of too hot, tried increasing the resistances to lower the current but still the output level got smaller gradually.
Any reasons for that?
Will using a current source instead of a resistor solve the problem?
Or maybe the DC of the buffer feedbacked to the I/V converter from the buffer output to negetive of LT1028 then I/V?
But BUF634 gives 0.5V DC output when standalone too.
Buffer output for PCM1794A-buf-bmp
Old 14th February 2015, 10:35 AM   #2
The bias currents of the output transistors is not fixed.
Cold operation will be different from warm and different again from hot.
You need as a minimum to add an emitter resistor to each output device.
You can also add an emitter resistor to each of the inputs.
Have a look at W.Jung's site.
I'm sure he explains.
regards Andrew T.
Old 14th February 2015, 02:47 PM   #3
Thanks so much for the reply.
So by using a current source part of the problem can be solved,
as bias current can be more constant.
Then resistors to emmiters.
Buffer output for PCM1794AHide this!Advertise here!
Too much DC at buffer's output ammel68 Analog Line Level 32 2nd September 2014 07:26 AM
PCM1794A tube-output DAC.... 4 chips detroyed wmincy Digital Line Level 23 4th June 2013 01:11 PM
YAHA with output buffer: need help TB Headphone Systems 3 25th August 2010 05:17 PM
Anyone used a PCM1794A with balanced output? hifimaker Digital Source 11 18th March 2006 06:36 PM
Berning output buffer Bill*B Tubes / Valves 10 16th October 2005 04:12 AM
