R-2R attenuator PCB layout question
Old 22nd October 2017, 01:00 PM   #71
OlegSh is offline OlegSh
Back panel done! Neutrik USB connector allows powering and programming the attenuator without opening it. I just have to remember how the peripherals are connected
Oleg
Old 27th October 2017, 11:58 AM   #72
Morde is offline Morde  Finland
I'm having some problems with the Arduino library IRLib2. When I try to run the code I get this kind of error message in IDE:
"In file included from C:\Program Files (x86)\Arduino\libraries\IRLib2/IRLibAll.h:22:0,
from AttenuatorArduinoCode.ino:2:
C:\Program Files (x86)\Arduino\libraries\IRLib2/IRLibDecodeBase.h:13:28: fatal error: IRLibProtocols.h: No such file or directory
#include "IRLibProtocols.h"
compilation terminated.
I have downloaded the IRLib2 library from GitHub and my libraries folder looks like in the attached screen shot. I think I do have the "IRLibProtocols.h" file, but it still doesn't work. Please help as I'm an Arduino noob.
My finished headphone amp projects: 1, 2, 3, 4, 5, 6, 7
Old 27th October 2017, 12:07 PM   #73
I have no experience with arduino IDE on Windows, since I work on Linux most of the time, but I see that there is directory separator problem in the error message that you get. I highlighted the problematic parts: backslash (Windows style) change to a slash (Unix/Linux style). Maybe this is the problem.
Oleg
Old 27th October 2017, 12:29 PM   #74
Ok, so where should I try to change the directory separator? In your attenuator code or in the IRLib2 library? I don't remember facing this kind of problems with my earlier Arduino experience: Arduino based LDR volume and source selection controller
Old 27th October 2017, 12:31 PM   #75
I guess in IRLib2 since in my code there are no directory separators used.
Old 27th October 2017, 07:50 PM   #76
YAY!! I got it working quite ok after I updated my ancient IDE version 1.6.1 to the latest 1.8.5. Also my Chinese LCD display had a different I2C address than what was on the original code. I changed this in the code (bold):
"LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7); // Set the LCD I2C interface"
Now I think it's just my encoder (Bourns PEC11R series) that needs the resistors and capacitors as described in the datasheets. Now it's like a machine gun when I turn the encoder.
The IR functionality I didn't test. What kind of remote control do I need for it? I have an old Logitech Harmony 555 remote that I can learn the commands if I just knew what to look for.
Old 27th October 2017, 07:56 PM   #77
Congrats for the first successful steps What you experience with the encoder is probably its contacts bounce, so RC filters recommended in the datasheet should fix it.
The remote can be any which has carrier frequency similar to your IR receiver. Using serial terminal you can learn all the necessary button codes and add extra "cases" to the "switch" clause to do the necessary functions.
Old 30th October 2017, 06:52 PM   #78
6 channel input selector PCBs arrived!
Old 5th November 2017, 02:32 PM   #79
Cleaned up and slightly optimized the code. Also implemented the input selection by using the numbers on the IR remote and standby mode (turns the LCD off, releases all relays which effectively sets max attenuation and mute, and disconnects all inputs). So far standby is only triggered by the remote control. In the future it should also be possible to engage by a long button press on the front panel.
Oleg
Old 20th November 2017, 03:32 PM   #80
To minimize the space the USB input takes inside the chassis I found a nice rugged USB-B socket from Amphenol (mouser part number: 523-MUSB-D511-N0). To make connection convenient I also designed a small adapter PCB for it (see attached).
Oleg
R-2R attenuator PCB layout questionHide this!Advertise here!
New project : R-2R Attenuator With Remote Control V2 bbp Swap Meet 179 15th November 2015 04:43 PM
amplifier PCB, question on overall grounding layout 00940 Solid State 28 27th September 2013 11:15 PM
Help with 6-Bit R-2R Relay Attenuator benproiii Analog Line Level 1 17th December 2012 04:58 PM
FS - R-2R Attenuator With Remote Control V2 Guiness Swap Meet 3 23rd November 2012 10:07 PM
UcD700 PCB Layout Question Randy Knutson Class D 7 19th June 2006 07:46 PM
