Input/output transformer question - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 16th December 2014, 02:59 PM   #1
Default Input/output transformer question
I've read Bill Whitlock's excellent guide on the Jensen website (http://jensen-transformers.com/wp-co...rs-Chapter.pdf) and understand the different design requirements for input and output transformers.
My questions is: if the total cabling distance between a source (e.g. DAC with 100ohm output impedance) and load (e.g. amp with 50Kohm input impedance) is around 1m, would it generally be the case that either an output or input transformer would be suitable for providing galvanic isolation between the two devices?
I'm thinking of the situation where a balanced output voltage DAC is driving an unbalanced amp input over a typical short interconnect. It would seem that this scenario satisfies the requirements for both input and output transformers to enable them to work well.
Thanks in advance for any advice shared.
Old 18th December 2014, 12:33 PM   #2
an input transformer is usually a better solution than an output transformer.
One of the jensen apnotes or "asxxx" sch that I posted elsewhere shows how to get a bal to unbal with galvanic isolation using an input transformer.
regards Andrew T.
Old 18th December 2014, 01:48 PM   #3
Make certain that the input transformer features a Faraday shield so to maximize wideband CMRR. Not all transformers advertised for input duty have them.
Ken
input transformer and impedance question milen007 Tubes / Valves 12 12th November 2014 01:50 PM
input impedance of output transformer gibson ga20rvt amp muscmp Instruments and Amps 4 13th October 2014 11:18 PM
Input transformer question BHD Tubes / Valves 6 19th August 2013 05:43 PM
Gainclone with transformer input question AmadeusMozart Chip Amps 1 26th July 2012 05:54 PM
Input transformer topology question zigzagflux Tubes / Valves 13 6th December 2011 09:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
