Is LR4 phase shift audible - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 8th December 2014, 10:56 AM   #1
Default Is LR4 phase shift audible
Considering going active on my current speakers (apogee centaur minors). Based on some other active projects with their big brothers it seems that a lower x-over point with LR4 electrical slopes is a good way to go. What I cannot find is any discussion over whether you need to put in a 360degree allpass delay on the high frequencies with LR4. There seems to be a consensus that we cannot hear a single cycle of anything but no conclusion that we therefore cannot hear a 360degree delay.
Does anyone have any experience of this?
Old 9th December 2014, 08:14 PM   #2
mondogenerator's Avatar
A delay of a single cycle could be audible, it greatly depends what frequency, and the corresponding time delay. It is measurable, I'm sure someone has tried that, but audible??? Contentious territory.
In my active two way, using 4th order active, i cannot hear the delay. The crossover is at around 2.8k so that's 0.35 milliseconds. Some may say I'm deaf, but i think an all pass to remove the cycle / 360* delay, would be more trouble than its worth. (i looked at it, and i needed 6-8 orders to do it, and the phase issues that caused put me off it entirely).
Every new piece of knowledge pushes something else out of my brain - Homer.....................Simpson
Old 9th December 2014, 11:48 PM   #3
I tend to feel the same, but have no evidence. I think will stick with simple for now.
Old 10th December 2014, 02:37 AM   #4
Adding an all-pass filter will render a crossover that most likely destroys the manifold advantages imparted by the LR filters (and other crossovers of like derivation).
Whilst LR2 (and like) crossovers result in a more pleasing delay characteristic, their audible advantages in two- and even three-way speakers are usually limited by the need to curtail the more audibly detrimental artefacts caused by operating drivers at their frequency extremes.
Note, however, that this discussion is separate from that of using a first-order all-pass filter as Linkwitz also describes in his 1976 JAES paper to compensate for the "lobing errors" produced by non-coincident drivers.
Check out Lipshitz and Vanderkooy's series of AES papers for a thorough guide to crossovers and (in particular) the addition of delay elements.
Is phase shift audible? Conrad Hoffman Everything Else 4 30th October 2014 07:52 PM
X-over Phase shift question kiwilistener Multi-Way 2 29th May 2012 11:49 AM
Phase Shift PWM Andrew Eckhardt Class D 6 14th November 2010 08:56 AM
Phase shift help (how's your maths?!) HankMcSpank Solid State 17 7th October 2009 11:15 AM
Zero phase-shift gareth Solid State 11 9th May 2008 05:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
