Preamp: opamp low pass filter for PS noise - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th November 2014, 04:43 PM   #1
Hengy is offline Hengy  Canada
Question Preamp: opamp low pass filter for PS noise
I am in the planning stages of building a completely custom preamp. I was running some simulations in ltspice, using the lt1115 opamp. It oscillated quite badly, so I tried putting a 68pf cap baypassing the feedback resistor. (The opamp was in a negative feedback topology) The cap fixes the oscillation, and created low pass filter, with a -3dB frequency around 30kHz.
This got me thinking: I'm planning on using a switching power supply. Its much cheaper, and I've seen them successfully used (no noise) in many projects on the internet.
So, does the low pass filter that fixed the oscillation also filter out PS noise? Say the switching power supply operated at a frequency of 100kHz, with some ugly 100mv spikes. If this is injected into the signal, will the low pass filter it out?
Im very interested to hear some explaination on this, as I do not have the knowledge to answer it.
Hengy
Old 26th November 2014, 04:15 AM   #2
that cap will do nothing to the supply noise. you will need decoupling caps for that.
Old 26th November 2014, 05:45 AM   #3
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
With an SMPSU, decoupling caps and series inductors. But inductors are only worth the effort if your source material is up to snuff.
Seek not the favour of the multitude...rather the testimony of few. And number not voices, but weigh them. - Kant
The capacity for impartial observation is commonly called 'cynicism' by those who lack it.
Old 26th November 2014, 10:42 AM   #4
DF96 is offline DF96  England
Correctly applied negative feedback reduces anything in the output which is not in the input. This includes stuff from the PSU. However, feedback does not work too well at higher frequencies as there is too little loop gain. You therefore need to reduce the PSU noise reaching the circuit, and use NFB as the 'final polish'.
Old 26th November 2014, 01:43 PM   #5
Thanks for the answers!
It was something that piqued my curiosity. I didn't expect it to be quite that easy, as I'm sure there would be a lot more on the subject if it was.
I do understand that decoupling caps as well as power line filters are the most effective way to reduce noise.
Hengy
Old 28th November 2014, 06:54 PM   #6
mondogenerator's Avatar
I once built a simple opamp rectifier and low pass, and i have been thinking about this myself. I considered using a power opamp for higher current capability, (opa541, LM12) but in not sure that i could get it to be stable at unity gain, or low (<10dB) gains, so i ditched the idea.
Every new piece of knowledge pushes something else out of my brain - Homer.....................Simpson
Active low pass filter for An opamp Jekku0966 Chip Amps 4 9th September 2014 06:47 AM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 14th September 2010 12:39 AM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 10:15 PM
PS for opamp preamp Tolu Power Supplies 1 31st October 2008 10:53 PM
New low noise opamp jackinnj Solid State 0 27th August 2002 07:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
