Pin 1: Multiple XLRs between two amplifiers - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 17th November 2014, 06:06 PM   #1
JFace is offline JFace  Canada
Default Pin 1: Multiple XLRs between two amplifiers
I am designing a headphone amplifier for use of live sound in ear monitoring. A mixing board will send two balanced signals for stereo operation, and the headphone amplifier will receive these two XLR connectors. How should I connect the pin 1 of the two receptacles on the headphone amplifier?
I am working with the assumption that all shields are connected to the mixer chassis. I am also assuming that the mixer earth may not be the same as the earth on stage.
Old 17th November 2014, 06:10 PM   #2
Pin 1 of every XLR should connect to the chassis by the most direct route possible. Google "Pin 1 problem" for details.
"Sadly, audio is like that. It is about the only branch of electronic engineering where lack of knowledge is regarded as a more advanced form of wisdom." http://scopeboy.com/amps
Old 17th November 2014, 06:13 PM   #3
I've read articles and posts on the matter. The simplification of this information seems to exclude multiple conductor scenarios.
This would create a chassis ground loop. Is this a problem?
Old 17th November 2014, 06:31 PM   #4
Looking at Rane's posted headphone amplifiers, they do connect pin 1 to chassis of all the XLR inputs. I suppose loops in shields don't cause any issues?
Old 17th November 2014, 07:31 PM   #5
dmills is online now dmills  United Kingdom
Nope, no issue at all.
The current flows in the chassis and not in the (internal) single ended reference (Unless you screw that up by connecting it to chassis at more then one point).
Now there is a proviso to all this, google "shield current induced noise" for the residual issue, which is seldom a problem in practise.
Also see Tony Walderons stuff on "designing interference free audio systems", worth the time.
Regards, Dan.
Old 17th November 2014, 07:57 PM   #6
From my reading of all the pin 1 problem papers/reports:
Pin1 always goes to chassis at the socket entry.
Preferably OUTSIDE the Chassis, rather than a pigtail looped inside the Chassis.
Pin1 is NOT part of the Signal.
The two signal pins 2 & 3 are taken to the signal processing In/Out of the circuit.
regards Andrew T.
Old 17th November 2014, 08:20 PM   #7
And the internal single eneded reference for the electronics is connected to chassis at ONE point (to define the common mode level), it never leaves the box.
Regards, Dan.
Old 17th November 2014, 08:59 PM   #8
Great, makes sense. Typically would you make this one connection between audio and chassis grounds near the input, or is it mostly a trial and error type thing?
I use Oshpark to prototype my designs. They are great, but they take about a month to get the pcbs in my hands. I'd like to iron out as many details as possible before the testing stage.
Old 17th November 2014, 09:00 PM   #9
forr is offline forr  France
forr's Avatar
Think of induced voltages in the signal path instead of worrying about all apparent ground loops which are often innocuous.
Old 17th November 2014, 09:09 PM   #10
Send a message via Skype™ to JonSnell Electronic
Balanced line audio has no reference to ground. The input floats. Pin1 and the shield are there purely for safety.
Support for Flying Mole, Allen & Heath, Valve amps and older designs. www.jonsnell.co.uk
Multiple Class-D amplifiers Cyberzim Class D 2 28th April 2011 08:15 AM
how to: multiple amplifiers? nige838 Solid State 1 6th February 2011 02:19 AM
Multiple Amplifiers, one set of headphones moronickaos Headphone Systems 0 6th June 2010 11:42 PM
using multiple amplifiers on one speaker saltmiser Everything Else 6 15th February 2009 06:14 AM
Bias for Multiple Amplifiers thespeakerguy Chip Amps 2 31st January 2009 09:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
