Hum issue in hpf circuit
Old 3rd October 2014, 12:40 PM   #1
giro1991 is offline giro1991  Scotland
giro1991's Avatar
Default Hum issue in hpf circuit
Hi, this is a continuation of my thread for XO/HPF combo unit with associated PSU (see sig).
The PSU and XO sections are working fine - but I'm left with humming in HPF section. Nearby transformer is not the cause because the XO works splendidly.
Currently in doubt about how some parts of circuit are connected - For ease I've circled 3 doubts on below schematic with questions.
I hope its these that are causing the problem.
It is a relatively simple circuit.
Refer to schematic for numbering:
1. How should the filter resistors be orientated (I currently have them horizontally, this could be wrong).
2. How should the op-amp V+ and V- terminals be connected relative to the PSU?
3. As you can see i'm left with four unterminated 'commons', 2 are signal returns, and 2 from the hpf circuit - I don't know how to connect these or if they should be left like this.
Thanks in advance
Michael Gerzon's Trifield decoder: foobar2000 plugin - free
Cheap 20bit ladder dac with 4 fs minimum phase filter TDA1306.pdf
Old 3rd October 2014, 01:16 PM   #2
I completed a 3way active speaker with 2ways in one box and a separate 1way for the bass only.
In the mid and treble box attached to the back of a small (5"+1" drivers) speaker I have a high pass filter and a bandpass filter as well as two chipamp channels & PSU. The Chassis is only 163x155x68mm, less that 1.7litres. It's all crammed in pretty tight.
I attached the input RCA directly to the chassis back panel. Expecting to have to change it after failed testing. But no measurable hum, no increased noise. It seemed to work !
regards Andrew T.
Old 3rd October 2014, 01:34 PM   #3
Forget about commons and grounds and other confusions.
EVERY signal is transmitted via a PAIR of wires. There are no exceptions.
Identify the pair of wires in every connection and twist them. solder at the 4 terminations.
The dual polarity PSU appears as an exception, but it is two 2wire connections where one wire carries the two return signals. We can return that signal as PSU Zero Volts. The two sets of 2wires becomes a twisted triplet.
regards Andrew T.
Old 3rd October 2014, 04:42 PM   #4
giro1991's Avatar
Hi andrew,
I was after instructions regarding how to connect up at 1,2&3...
You mention terminations but I cannot tell from what you wrote what to do exactly, still?
Old 4th October 2014, 12:20 PM   #5
Find the connection for the input signal.
It must be 2 (two) wires.
The two wires have four ends. Solder these four ends to the respective terminals.
The input socket gives you two terminals. The Receiver PCB has two input terminals. Solder to those four terminals.
Repeat for EVERY connection.
regards Andrew T.
Old 4th October 2014, 07:20 PM   #6
jeffremus is offline jeffremus
https://www.google.com/url?sa=t&sour...TJXSy2MiayNZJw
Old 4th October 2014, 07:27 PM   #7
I would try going with balance inputs and ground as little as possible. Look up CMRR for great materials noise issues. The MC330079 is what crown audio uses but the opa op amps are better
Old 4th October 2014, 07:38 PM   #8
Old 5th October 2014, 08:12 PM   #9
The input to that section is a two wire connection. You must keep those two wires close coupled.
The output from that section is a two wire connection. You must keep those two wires close coupled.
regards Andrew T.
Old 6th October 2014, 03:56 PM   #10
giro1991's Avatar
Andrew, you mean like this? (see attachment)
Hum issue in hpf circuitHide this!Advertise here!
Hum issue e_fortier Class D 6 3rd March 2009 03:42 AM
Adcom 565 - Hum issue a.wayne Solid State 0 19th February 2009 06:14 AM
hum issue with Aleph P1.7 Stefanoo Pass Labs 9 31st December 2007 09:19 AM
another Hum issue LM3875 sts9fan Chip Amps 43 10th September 2007 05:06 PM
VERY loud hum issue 5th element Solid State 23 30th May 2004 06:37 AM
