Line level / unity gain vacuum tube circuits - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th September 2014, 04:09 PM   #1
Ensoniq is offline Ensoniq  United States
Default Line level / unity gain vacuum tube circuits
Looking for simple circuits with vacuum tubes at line level, not preamp or amplifiers just so I can integrate a tube circuit before an amp for line level signals and have audio pass thru it.
Old 10th September 2014, 04:29 PM   #2
DF96 is offline DF96  England
For unity gain you need a cathode follower. In all cases this will add a little noise and distortion. In some cases it may also reduce the driving ability of the source. Only in unusual cases will it enhance the source and increase driving ability - typically where the source itself ends with a poorly designed valve stage.
Old 16th September 2014, 06:39 PM   #3
Bigun is online now Bigun  Canada
Bigun's Avatar
A simply buffer can be very handy if using a low impedance volume potentiometer. A simple approach that is popular is the Nelson Pass B1, all JEFT. You could make a tube version. Ideally, you want to use tubes with high transconductance, such as the 6DJ8. If you want to get fancy then look up some of the circuits by Allen Wright(?) - some of them are ultra-low distortion and will be close to transparent.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th September 2014, 03:01 PM   #4
Don't wanna get fancy at all haha. Want as simple as possible
Old 17th September 2014, 03:35 PM   #5
Bigun's Avatar
The simple as possible is probably to build the PASS B1 buffer. Although I've never compared them I expect it will give up nothing in comparison with a tube buffer.
Old 19th September 2014, 04:52 AM   #6
What about this 6n3 based 'buffer'?
DIY Amp Board Tube 6N3 Buffer Audio Preamplifier Pre Amp Board HiFi Amplifier | eBay
Old 19th September 2014, 03:02 PM   #7
As simple as possible is to have no buffer. Some 'buffers' are actually signal degrader units.
Old 20th September 2014, 03:06 AM   #8
ammel68 is offline ammel68  United States
Originally Posted by Ensoniq View Post
I would avoid most of those eBay tube buffers as most are trying to operate the tube at voltages that are much too low. As a result, the tube is trying to work outside its ideal operating range.
Like transistors, tubes have to be biased correctly to sound their best. I don't know of many tubes that are happy with 24V going to their plates.
Not sure if there's a certain tube that's best suited for a buffer, but I've gotten great sound from the low gain(or mu) 6CG7.
You might get more replies if you post in the Tubes/Valves section under amplifiers.
Good luck...
Old 20th September 2014, 11:24 PM   #9
georgehifi's Avatar
Send a message via MSN to georgehifi
Just use this a direct coupled feedabck free fet input BJT output that has 1ohm output impedance at 80ma Class A buffer, the BUF03 it's magic. And is short circuit protected and can even drive low impedance headphones as well.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old Yesterday, 07:15 PM   #10
Cheers George
Is there any schematic for it?
A Heretical Unity Gain Line Stage part III SY Tubes / Valves 253 9th October 2013 02:35 PM
A Heretical Unity gain line stage SY Tubes / Valves 86 26th April 2013 10:18 AM
Simple Line Level Mixer (Unity Gain) Noumenon Parts 3 29th December 2008 11:34 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Voltage regulators for line level circuits HarryHaller Solid State 64 24th April 2003 05:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
