crossover / summer for "2.1" active or passive - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 2nd September 2014, 07:33 PM   #1
Ensoniq is offline Ensoniq  United States
Default crossover / summer for "2.1" active or passive
i wanna take a 2 channel L/R stereo source and have it feed 3 amps:
Left, Right and Subwoofer.
Im thinking of crossing over at around 100hz.
which would be easier (minimal components) passive or active?
and how do i take the Left ant Right and summ them up to feed the sub amp?
Old 9th September 2014, 07:45 PM   #2
Zero D is offline Zero D  United Kingdom
Hi, passive & easy is like this in my screenie.
Active requires an OpAmp/Components/Supply/Case
I'm presuming the SubAmp has a 100Hz etc filter in it ? If not, then more is needed for either solutions.
Old 9th September 2014, 09:17 PM   #3
No i don't have crossover yet.
Btw, active means before amp and passive means after amp correct ?
Old 9th September 2014, 09:18 PM   #4
Reducing input caps on the L+R stereo amplifier an idea.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 10th September 2014, 02:18 AM   #5
Do you have the Sub Amp yet ? If not try & get one with a Xover built in. Also look for one which has L & R inputs which are merged internally. That way problem solved !
Active means any powered circuit, which in this case would be the OpAmp solution. Passive means unpowered, which could be before and/or after the Amp.
EDIT
Of course you would need a high pass filter for the L & R too, which matches the 100Hz etc low pass !
Old 10th September 2014, 02:31 AM   #6
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Passive is fewest components and normally sounds best. However a passive XO at 100Hz is going to call for some fairly huge inductors (in the range of 10H) to operate at line level. Probably you'll have to wind them yourself (on gapped ferrite cores) which will take a couple of hours for each.
You could employ the design resource here - Passive Crossover Design Equations Formulas Calculator - Two Way Second Order Network Chebychev Bessel Butterworth Linkwitz-Riley
I have the advantage of having found out how hard it is to get to really know something... how easy it is to make mistakes and fool yourself. - Richard Feynman
Old 10th September 2014, 02:41 AM   #7
@ abraxalito
When you say "Line Level" i expect you actually mean output from the Sub Amp, not PreAmp output Line Level. We don't want to confuse the OP
For eg only, a single 10k resistor & a 0.159uf capacitor before the Sub Amp = 100Hz cutoff.
Old 10th September 2014, 03:35 AM   #8
abraxalito's Avatar
No, I was really meaning line-level - or I'd have written 'speaker level'
Yes you can do a first order LP without inductors but I was assuming the OP would want a bit more than a first order.
Old 11th September 2014, 03:58 PM   #9
post6 link to a passive crossover calculator.
It shows a 2pole crossover consisting of only one capacitor and one inductor in each filter.
How can the roll-off characteristic be changed through the continuum of Linkwitz, Bessel, Butterworth, Chebychev?
regards Andrew T.
Old 12th September 2014, 12:56 AM   #10
abraxalito's Avatar
By choosing the component values listed under those particular headings. Each of them is a different trade-off between passband flatness, steepness of roll-off, and phase response.
The Synergy "Active" Crossover wintermute Analog Line Level 159 30th July 2014 01:15 PM
"Wineclone" Battery-powered Amplifier SUMMER SALE! $50 off! gripracer Swap Meet 19 31st December 2010 09:56 PM
Idea for "Balanced" Passive crossover- opinions? clm811 Multi-Way 10 26th March 2010 08:27 AM
Balanced "passive" crossover troystg Analog Line Level 6 14th September 2009 03:53 AM
Need Help Downloading "Passive Crossover" FRD!! kelticwizard Multi-Way 16 8th December 2002 10:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
