"Lehmann" Buffer Output Transistors. - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 20th August 2014, 05:08 PM   #1
ammel68 is online now ammel68  United States
Default "Lehmann" Buffer Output Transistors.
I have a question about the BD139 & BD140 output devices in the Lehmann buffer circuit below.
The schematic calls for the BD139 & BD140-16 devices which have the highest hFE.
What happens if you substitute the lower hFE devices like the BD139 & BD140-6 or -10?
Thank you...
Old 21st August 2014, 06:39 AM   #2
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
I would imagine that you would see a slight increase in distortion at higher output levels when driving lower impedance loads.
Installing and using LTspice. From beginner to advanced.
Old 21st August 2014, 04:22 PM   #3
I was concerned of saturating or "overloading" the output transistors since the BC transistors are also the highest hFE "C" grade devices.
Old 22nd August 2014, 07:47 AM   #4
Calvin is offline Calvin  Germany
Calvin's Avatar
the BC drivers are biased just under 10mA, which is quite a lot.
even if the BDs were runnung on 100mA of bias current theyd require less than 1mA of Base current.
So nothing to worry about.
THD may rise a bit with lower hfe BDs but on a rather negligable niveau.
This Buffer is the second simplest form of an Diamond Buffer.
The drivers run on ~9mA bias, the outputs on 40-45mA.
Heat power loss of the BCs is ~140mW and ~550mW for the BDs.
THD improves when You connect V12s collector to V10s emitter and V9s collector to V11s emitter.
Also the drivers losses reduce considerably down to ~10mW, allowing for SMDs.
The BDs power losses incerease though by ~100mW to 650mW.
jauu
Calvin
Old 26th August 2014, 04:35 PM   #5
Hi Calvin,
Does this look right?
Is there anything else you would change about this buffer to improve its performance?
Thank you...
Old 26th August 2014, 05:23 PM   #6
Calvin's Avatar
not quite right, just one half
Follow the link to my website, bipolar Buffers and see Fig.5 and associated description
jauu
Calvin
Old 26th August 2014, 05:52 PM   #7
Bootstrapping. Not as good as CCS but simple and with lower voltage drop over the output transistors.
Old 27th August 2014, 10:09 AM   #8
stormsonic's Avatar
He preciselly followed your instructions. He didn't notice small typing error
Old 27th August 2014, 10:32 AM   #9
Should read: higher output voltage swing. Sorry for my bad English.
Old 27th August 2014, 02:19 PM   #10
Calvin's Avatar
uups , oh ehm, yes, my fault.
Got my new glasses just later that day
jauu
Calvin
Stupid Q ... what determines "signal ground" on a unity gain buffer? vputz Analog Line Level 10 28th December 2013 06:12 PM
"Zen I / V Converter / buffer b1" make dac/preamp chatoyant Digital Line Level 2 19th December 2012 12:54 PM
SOS... problems with Lehmann BCL ("Lovely Cube")... Miky2011 Solid State 2 31st October 2011 10:53 PM
All FET folded cascode driver for "JLH"-buffer with no GNFB revintage Solid State 10 29th January 2010 09:58 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
