Minuature Low Pass Filter - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old Today, 10:50 AM   #1
Default Minuature Low Pass Filter
Hey wise ones
I'm building a portable speaker and i'm trying to cram it into the smallest space i can. It has a sub and needs a low pass filter feed it.
So far i've build a simple active filter off a lm358. The size came to 10mm x 40mm x 8mm ( w l h ) It's small but it's by far the biggest component. Bigger than my bluetooth module and amplifier. It's height is the main problem as i'm using hole mounted components. I could switch to SMCs but it looks fiddly ( i struggle with matrix board!)
Any suggestions on how to make it smaller.
Audio quality for the sub is not a concern here.
Power supply is up to 12v
Mono bass is ok
Max height is 5mm
low pass filter panos1 Analog Line Level 14 15th December 2013 09:10 AM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
low pass filter crazyant Car Audio 3 15th September 2005 06:15 PM
Low pass filter Fin Digital Source 2 29th December 2003 02:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
