Low pass filter for Bitstream DAC.
Old 16th August 2014, 08:06 PM   #1
elektryk is offline elektryk
elektryk's Avatar
Default Low pass filter for Bitstream DAC.
Hi.
I have created DAC using UDA1320, it works normally, but I feel that it sounds a bit better (softer) with LPF.
I already have passive 1st order LPF (300R+10nF), because this IC gives relatively high output level.
Is it worth to make sth more sophisticated (I have at the disposal NJM2068 or NJM4580 for active filter), or in this case that easy solution (passive 1st order) will be the best?
Also I can make output stage on triodes (ECC88, E88CC), but does it makes sense to do it with this "low cost" DAC?
Old 17th August 2014, 01:26 AM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I'd suggest a passive (LC) low pass filter. Having 300R in the series arm makes the RC LPF a bit difficult to drive at HF for a normal opamp, bitstream DACs do put out a fair amount of ultrasonic energy. An inductor's easier to drive.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 17th August 2014, 10:24 AM   #3
elektryk's Avatar
Could You recommend any well-functioning schematic?
Old 17th August 2014, 01:15 PM   #4
abraxalito's Avatar
Here's a schematic and plot - the 33mH inductor is by Fastron, available from Mouser.
Old 17th August 2014, 03:21 PM   #5
elektryk's Avatar
Thanks, can it be something like this?
COIL0810-33 FERROCORE - Inductor: wire | TME - Electronic components
Meanwhile I run this stage using ECC88 (other heaters), because I had almost all needed parts.
http://4.bp.blogspot.com/-qTXVb9cqCQ...in_stage15.png
Fred's Vacuum Tube Amplifier Blog
I'm testing it, but mains hum is a little too big, maybe 22uF filtering capacitor Isn't enough?
Old 18th August 2014, 01:18 AM   #6
abraxalito's Avatar
You could certainly try with that inductor - it is different from the one I recommend in two respects. First its unshielded so may well pick up hum and noise from adjacent circuits. Second the DC resistance is considerably higher (90ohm vs 26). The Fastron details are here :
07MFG-333J-50 Fastron | Mouser
Low pass filter for Bitstream DAC.Hide this!Advertise here!
low pass filter for DAC output kinku Analog Line Level 83 4th July 2014 12:17 PM
Do I really need any DC output capacitor between a DAC chip and the low pass filter ? ygg-it Digital Line Level 3 7th April 2011 12:16 AM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
Low pass filter? happyb Car Audio 5 11th December 2006 09:47 PM
Low pass filter on DAC output Tenson Parts 1 12th September 2006 02:10 PM
