looking for programmable eq chip / pcba module ??
Old 15th August 2014, 12:25 AM   #1
Ensoniq is offline Ensoniq  United States
Default looking for programmable eq chip / pcba module ??
looking to build or even buy an inexpensive audio eq/dsp chip or pcba that will allow me to set an eq curve preferably parametric eq , even thou graphic eq will do just fine if it has around 10 bands.
so it can be programmed and "set and forget".
i thought there might be some with usb port so i can set the eq with a pc thru usb port but couildnt find cheap ones like that.
preferably with analog in and out (so i guess with built in a-d-a converters).
Old 16th August 2014, 04:27 PM   #2
mickeymoose is offline mickeymoose  Canada
LMC835 by National. Discontinued but available on ebay. E
looking for programmable eq chip / pcba module ??Hide this!Advertise here!
Weird problem with a preamp with 3 band EQ module csom Analog Line Level 31 9th July 2013 02:31 PM
10 band Equalizer on a Programmable Chip hwoods Digital Line Level 1 18th November 2009 09:53 PM
Computer Programmable Custom Band EQ matt09 Digital Line Level 1 13th March 2009 06:35 PM
Silicon Chip Ultra LD Mk2 Module pheonix358 Solid State 0 30th July 2008 06:25 AM
(Aus) Parametric EQ from Silicon Chip 07/96? Cloth Ears Subwoofers 3 20th April 2007 01:19 PM
Copyright ©1999-2017 diyAudio
