LECUA 1000 attenuator from Luxman ? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th August 2014, 11:12 AM   #1
pw8888 is offline pw8888  France
Default LECUA 1000 attenuator from Luxman ?
Hi everybody...
a little bit of a basic question here...
what do they mean by :
The Luxman L-590Ax builds upon renowned L-590A II and improves on it especially with the new LECUA 1000WM attenuator (the LECUA stands for Luxman Electric Controlled Ultimate Attenuator and the WM stands for Weighting Matrix) and the circuitry that has been adopted from Luxman´s flagship C-1000f control amplifier and B-1000f mono power amplifier. Luxman claims the LECUA 1000WM to be the ´ultimate attenuator´ that aspires to be the first absolutely lossless attenuator ever. It converts the music signal from a voltage into a current, controls gain, and then reconverts the current into a voltage. A position of the volume knob is detected by sensors to be consequently evaluated by processor board that controls the current switches combinations. As the LECUA does not imply any impedance changes there is no deterioration of S/N ratio and frequency response remains totally uniform and there is virtually zero tracking difference between both channels. The entire process is carried out in analog domain including electrical suppression of RFI and EMI interferences.
would it be better than a Alps RK50 per exemple ?
or any stepped attenuator ?
sorry for this basic question ; help greatly appreciated :-)
thanks
P
Old 17th August 2014, 10:28 AM   #2
georgehifi's Avatar
Send a message via MSN to georgehifi
P
"The LECUA 1000WM circuit converts the music signal from a voltage into a current, switches gain by means of switching on the attentuaes, and then reconverts the current into a voltage. The entire process is carried out in the analog domain."
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 17th August 2014, 11:07 AM   #3
sorry for the ultra basic question...
but i was not acccurate enough probably...
i was wondering DESIGN AND SOUND wise if that is the "best" solution to use in a preamp....
thanks
P
Old 17th August 2014, 01:20 PM   #4
analog_sa's Avatar
This looks like a simple buffered ladder attenuator. There was a mention at 6moons that the signal passes through 2 resistors at any given volume setting. Whether there is any form of V/I and I/V i cannot say from the meager info, but quite possibly controlling the gain in the current domain is a better idea when dealing with relatively high Ron switching elements. Nothing at all revolutionary.
In the end, as with most other things it's all down to the specific implementation. Per example - the type of resistors. Saw no mention of z-foils but maybe they are just being modest
Old 17th August 2014, 01:21 PM   #5
thanks for your explanation !
Old 17th August 2014, 01:22 PM   #6
Is there any "kit" or DIY equivalent out there ?
thanks for sharing...
P
Old 30th January 2016, 10:58 PM   #7
Old 1st February 2016, 01:15 PM   #8
maxw is offline maxw  United Kingdom
maxw's Avatar
One DIY implementation is my MDAC attenuator. Details here:
Solid state R2R attenuator using analog switches or multiplying DAC
Measurement in this post:
I really like the design, I'm still using mine every day. I am also designing a newer version for a new preamp.
bbp also made version but with separate analog switches instead of using a R2R DAC IC:
Promotion: Hi-end Volume Control Module,Ultimate Attenuator for Audio
He also posted excellent measurements.
1x PGA2320 attenuator & 1x 16bit MDAC attenuator maxw Swap Meet 5 4th August 2014 09:31 AM
luxman help orsen Solid State 2 2nd July 2014 11:32 AM
Luxman C-1000 Carlosraj Solid State 5 2nd March 2012 07:38 AM
Luxman joelfl Solid State 3 18th August 2010 10:05 AM
Luxman D-404 Rob M Digital Source 0 21st November 2004 07:44 PM
Copyright İ1999-2017 diyAudio
